Lots of folks have made one-shot oilers on RF-45 type mills. Typically, they cut grooves in the face of the saddle, to distribute the oil more uniformly on the surface of the dovetail. This is quite doable -- *if* a person has a second mill. But I consider myself lucky to have a single mill.
So I'm interested in hearing some detailed accounts of how people have made the oil grooves without using a mill. I suspect that a Dremel or small router in a custom-made guide-block base with a grinding wheel is the way to go. But perhaps someone has tried doing this milling on a drill press, or with some other approach. Maybe someone has used a 4" angle grinder.
I'm particularly interested in knowing about use of small grinding wheels for cutting the grooves, and how feasible this is.
Anything to report or suggest?
Thanks!!
Dave Kellogg
