586,060 active members*
3,736 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Having trouble tapping steel.?
Results 1 to 9 of 9
    Mar 2010
    14
    Im trying to tap using a 1/2 tap. I drill with the 27/64 and as soon as i start the tap it locks. So that means im probably try to tap hardened steel. I cant for the life of me to get it going so i have been tapping using a 15/32 drill. I tap it with success. Is there an easy way to tap hardened steel?
    Also im tapping the holes and using a nut threaded on first. Then thread the bolt in the hole as far as it will go and then tightened the nut. I am correct as the nut will take the brute force of the impact correct.
    I am not a machinist.
    Jan 2007
    1389
    My guess and I am usually 100% correct, is you bought a cheap tap.
    Mar 2010
    14
    irwin... What kind do you recommend for hardened steel?
    Dec 2004
    783
    Quote Originally Posted by jpatz18 View Post
    Any besides Irwin check Mcmaster Carr for good taps, and some info on the different types.
    It's probably not hardened steel if you can tap it with a bigger starting hole, I would say the tap is too dull, or it's a bottoming or plug tap, in which case starting with a regular or gun tap would be best, finish up with the bottom or plug tap if it's a blind hole.
    Sent from tapatalk
    Mar 2008
    240
    If you are tapping 1/2-13 than 27/64 is your tap drill. If you drilled the hole with a HSS drill than you do not have hardened steel. Problem is your tap.
    1943
    Are you using a bottoming tap?
    Jun 2007
    3757
    Taper or intermediate tap, and use some sort of cutting agent. Don't do it dry.
    Sounds like a cheap tap. Does it have nice sharp cutting edges? The the cheap ones have hard burrs on them and they will only cut wood, and make a mess of that.
    Jul 2010
    492
    get yourself a nice guhring spiral flute tap !
    Apr 2006
    3206
    At least there's an admission to not being a machinist... For that, help without the sarcasm is cheerfully granted.
    As noted, if it's steel that's truly hardened, you wouldn't be able to drill it with a regular high speed steel (HSS) drill. Since you don't mention which 1/2" thread, we'll assume it's a 1/2-13 (13 is the number of threads/inch,,, and a common one for that diameter), and using the machinist's bible.. Machinery's Handbook (15th Edition, in this case.. ) the hole needs to be .417-.434" dia. In your case you want it to be on the big side.
    There are tap guides with spring loaded tips... You should drill the hole (you're using a drill press, right?), and leave the part clamped in place. Put the tap guide in the spindle and use your tap wrench to turn the tap while the tap is being pushed gently into the hole (no, don't turn the spindle on). This will keep the tap aligned nicely and help minimize binding from the tap going in sideways.
    Don't use a cheap tap. Get a Guhring, OSG, Emuge, or other quality brand. Be nice to it and it'll last you a long time. I like 3 flute taps, "Plug" for general purposes. Get a can of Moly D or some kind of cutting oil you can dab on with an acid brush.
    .... If you had a CNC, it'd look like this...
    How to tap stainless steel - YouTube
  1. Tapping Stainless Steel
    By emc3zach in forum Tormach Personal CNC Mill
    Last Post: 08-14-2012, 05:11 AM
  2. Trouble tapping a blind hole
    By subi4ester in forum Haas Mills
    Last Post: 10-29-2010, 10:24 PM
  3. 1000 RPM too much for tapping steel?
    By kendo in forum MetalWork Discussion
    Last Post: 05-06-2009, 12:37 AM
  4. Tapping Steel - 35 Rockwell C
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 01-13-2009, 06:24 PM
  5. Trouble cutting steel with TAIG
    By L2A3 in forum Taig Mills / Lathes
    Last Post: 03-12-2008, 03:15 AM
