586,077 active members*
3,650 visitors online*
Results 1 to 7 of 7
    May 2013
    select multiple instances of same part
    Hi, this is my first post.
    I've been using solidcam for a few weeks now, trying with some (slow) success to mill some parts for furniture out of timber.
    I have an assembly with multiple instances of a three different parts (about 60 in all). It's rather tedious to go through each part selecting the same thing to define geometry (drilling, profiles, faces for HSS) separately for each instance.
    Is there not some way to select every instance of a feature? OK I could do it for most of the holes, but the profiles and faces are eluding me.
    Thanks for your help,
    Andrew
    Oct 2007
    499
    Program one part.
    Then select all the jobs in the Job Tree
    Right click and select "Transform"
    Choose the option "Translate" and input the incremental values of your repeat parts.
    Click OK and voilá, there are multiple instances of your part.
    It's all there in the help screens
    Jul 2007
    378
    Quote Originally Posted by Brakeman Bob View Post
    Program one part.
    This method only works if your post supports "transform operations".
    May 2013
    37
    Transform Tutorial
    glovebox20 is right, if the transformation does not work for you, this means that you need to complete the code postprocessor
    Of course you can do it another way. For example, such
    Attachment 184686
    Attachment 184688
    Attachment 184690
    May 2013
    Thanks for your quick responses.
    Because I'm trying to get the most out of a sheet of bamboo which already has some irregular holes in it, the parts are not evenly distributed across the board, so I'm guessing the transform technique would not work for me.
    I can go through the design tree and select each instance of, in one case, sketch 5, but I thought there may be a more time -efficient way.
    Any other ideas?
    Oct 2007
    499
    How about taking the work datum out of the cutting program and then calling the cutting program from a control program that has the different work datums declared in that.
    In FANUC that is either using G10's to set multiple instances of G54 or using G54, G55 etc. to set multiple instances via the datum table.
    Nov 2007
    330
    You can still use transform for irregular spacing. Transform / List.....and then put in the coordinates of each origin....BINGO!!
  1. Same Part Multiple fixtures?
    By pp-TG in forum Mastercam
    Last Post: 06-15-2013, 05:28 AM
  2. select reverse of the part
    By thefu in forum GibbsCAM
    Last Post: 07-11-2012, 12:06 PM
  3. how to select only certain part as drive
    By ataxy in forum Mastercam
    Last Post: 11-27-2008, 01:37 AM
  4. select multiple geometry for profiling
    By kendo in forum EdgeCam
    Last Post: 11-25-2008, 06:46 PM
  5. Machining Multiple of the same part
    By Hellbringer in forum Benchtop Machines
    Last Post: 02-18-2008, 11:21 PM
