586,058 active members*
3,339 visitors online*
Results 1 to 7 of 7
    Mar 2006
    fanuc 11m parameters
    I am trying to change paramter 9100 but it says its a locked parameter, but I have PWE on, please help if you can.
    24221
    Are you trying to change it in the diagnostic screen instead of parameter screen?
    I believe on the 10,11 you have to set the P8000 to all ones for the 9000 parameters.
    Al.
    Albert E.
    24221
    Here is the pdf for loading from disk via RS232
    Al
    Attached Files Attached Files
    Albert E.
    Mar 2006
    Thanks for all the help, But my problem is solved .
    Fanuc 11m parameter 9100 bit 2 turned on my helical back on, please you guys make sure you back up your parameters on these old controls, fanuc claims they dont have data this old, and will make you rebuy your options.plus they dont have agood handle on them any more
    Dec 2004
    185
    Hi All (and you Al... ; )
    I have an 1985 vintage lathe with fanuc 10t.
    I have backed up my parameters, but how can i be sure i have got them all??
    Thanx
    Pieter
    24221
    Print out a hard copy for one and check the parameter range, make sure you have right up to the 9000's
    Al.
    Albert E.
    Jan 2007
    93
    Re: fanuc 11m parameters
    For changing locked parameter, you will have to delete all parameter & start from loading optional parameter in Fanuc 10, 11 & 15 system.
    Before deleting pl take a full back up of machine data, plc data - counter, timer, keep relay & data table & part program.
  1. Parameters FANUC O-L
    By nsdjole in forum Fanuc
    Last Post: 04-25-2022, 05:29 PM
  2. Replies: 3
    Last Post: 10-22-2020, 09:20 PM
  3. fanuc 11t parameters
    By aguilar in forum Community Club House
    Last Post: 06-26-2013, 07:40 PM
  4. Parameters for YAM CK-5, Fanuc 10T
    By gisab in forum MetalWork Discussion
    Last Post: 12-07-2009, 09:39 AM
  5. Fanuc 0T G83, G84 parameters
    By davisboys in forum Fanuc
    Last Post: 03-18-2007, 05:29 AM
