586,121 active members*
3,758 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > HELP! FINDING SUPPLIER FOR 4140 IN FLATS OR PLATE
    Nov 2006
    303
    We make a part that requires a blank size of .625x1.5x5.50". We have used blanks up to 6" long and could technically use 3/4" thick material if we needed to. We require the supplier saw cut to blank dimensions.
    Material needs to be 4140 or 4340 Annealed. We typically use CDA or cold drawn annealed. Could possibly use hot or decarb. The main issue here is the price. We have seen price for this material shoot over $4.00/lb from our supplier which is Alro. I am having a hard time swallowing that price.
    Can anyone recommend other suppliers to check with that have plate or flats of these materials? NO, rounds will not work for this. However, due to all the problems buying the stuff, we are going to gear towards converting the part to run off a mill/turn so we can use bar.
    Our typical order is about 200lbs.
    I would also add that we may consider changing the alloy to a more popular alloy in flats. Still needs to stay a med carb, structural steel though.
    Nov 2006
    303
    Anyone?
    Jun 2005
    232
    PPC metals phone 704-283-9122 they can do everything you asked in your post .
    Tim
  1. NEED HELP finding tooling supplier in Texas!
    By joshforeman in forum Commercial CNC Wood Routers
    Last Post: 09-02-2011, 05:59 PM
  2. Need help finding Steel Supplier...
    By Mini-MillX2 in forum MetalWork Discussion
    Last Post: 07-06-2011, 05:05 PM
  3. Matrix Plate- A2 or 4140? Newb needing help machining
    By Odin in forum MetalWork Discussion
    Last Post: 02-15-2011, 06:39 PM
  4. 1020 plate supplier problem
    By mc-motorsports in forum MetalWork Discussion
    Last Post: 04-26-2009, 04:40 AM
  5. Need help finding rack supplier in UK
    By Smiler in forum DIY CNC Router Table Machines
    Last Post: 07-12-2008, 06:14 PM
