This is hard to pass up at $10k!!!!!:violin:
150818969793
Al.
150818969793
Al.
Albert E.
Rockcliff Machine Inc.
http://www.rockcliffmachine.com
I have about half a dozen, time to cash in!
Al.
Albert E.
it was a great servo card in it’s day, but I think the seller should take a look at his “9” key it must really be sticky
I am laughing and joking now, but what if it really sells
That's very interesting, I should consider applying some power to mine on a future project, I would be curious to see if it even powered up, it's been sitting in a rittal enclosure for at least 10 plus, years
if my memory is correct, I believe the last time I had it running, I was using it with cadtodmc? or cadtogcode? it was some software from galil, it was very limited on the software control end, but I really liked the functions of that card it really can be configured to do anything thru the galil programming language which was perfect for industrial machine motion type stuff,
The really nice operator interface program they had for it was Opint, I have used it for many projects.
Back gauges, a couple of Cincinnati point to point mills, tube cut off lathe, 3 axis line Punch for a few.
Once you get the hang of it, screens can be made up in short order.
I can also convert the single axis to four!
Al.
Albert E.
Hi Al_the_man ,
Al.
I have some DMC-1040 and 1540 and look for a long time for a software . What is Opint , where I can get it ?
Hans
P.M. sent
Al.
Albert E.
Hello Al,
I'm interested in Opint as well, where can I find it thanks?
rgds
Dave Hall
P.M. sent.
Al.
Albert E.
