586,115 active members*
3,232 visitors online*
    Sep 2012
    Extra Long Reduced Shank Drill
    I am looking for a 41mm drill with a 1/2" shank OAL - 8" - 9" for drilling hole 7" deep, material is aluminum.
    Any suggestions on where I can buy this ?
    If not, suggestions on ways to drill this hole (not a thru hole) using a different tool.
    Jan 2011
    380
    I would invest in an insert style spade drill. Works good for things like this. MSC has a style of insert here: Spade Drill Inserts - Indexable Cutting Tools | MSCDirect.com
    Just pick the one you want and match it to a holder, should be good to go
    Sep 2012
    Thanks for the suggestion and link.
    Feb 2007
    966
    Do you have a lathe ? Make an extender shaft from 3/4" rod.
    Drill and ream 0.500" in one end and turn the other to 1/2"
    Use 2 set screws and make a small flat on the drills shaft.
    Larry
  1. Reduced Shank Milling Tools
    By AcryNom in forum CNC Tooling
    Last Post: 10-08-2015, 06:27 PM
  2. reduced end mill with 1/4 Shank
    By adamski07 in forum CNC Tooling
    Last Post: 04-07-2013, 04:32 AM
  3. Extra-Long End-mill - Dangerous or not?
    By eranglr in forum CNC Tooling
    Last Post: 09-21-2010, 03:37 AM
  4. Extra long router bits for foam
    By xshaper in forum News Announcements
    Last Post: 10-14-2007, 06:45 AM
  5. Extra long router bits
    By whiteriver in forum Material Machining Solutions
    Last Post: 06-06-2005, 09:21 PM
