586,457 active members*
3,454 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VF-2 Z Axis Waycover Replacement
    Sep 2005
    39
    Bought a new one for the machine and see that the configuration is totally different than the original. Anyone have installation instructions for the new style covers?
    Jan 2012
    21
    I just put on a new style z axis cover on one of my old 90' models last year, they don't come with instructions.
    Pull all the screws out of the rails holding on the old one. Clean and reinstall the new one. The trick is to re configure the long rail spacers so they allow the cover to collapse and not bind when the head is down in Z.
    I have 5 long spacers then the Z axis cover then the outside rail with the c'sunk holes all sandwiched together, in that order.
    Good luck,
    Sep 2005
    39
    I'm back in business... keeping the old long spacers from the previous cover was the trick. Without the spacers, the new accordion style cover binds up. Thanks!
  1. X axis ballscrew replacement
    By gamila in forum Fadal
    Last Post: 06-06-2015, 12:00 AM
  2. LB 15 x axis shear pin replacement
    By meadowtech in forum Okuma
    Last Post: 06-01-2011, 11:03 PM
  3. Shizuko AN-S X Axis Ballscrew Replacement
    By GTRClive in forum Linear and Rotary Motion
    Last Post: 02-01-2010, 07:34 PM
  4. Axis Motors Brush replacement
    By Delw in forum Fadal
    Last Post: 02-11-2009, 05:35 PM
  5. MV Jr. Z Axis thrust bearing replacement
    By TWyatt9 in forum Mori Seiki lathes
    Last Post: 11-26-2007, 01:19 PM
