586,110 active members*
3,289 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > linistepper with toshiba mp4104 transistor array
    Jun 2012
    11
    Smile linistepper with toshiba mp4104 transistor array
    i have some toshiba mp4104 modules (4 transistor array), and i wish use them in place of tip 122 in the linistepper driver ,any ideas plz help..
    May 2013
    128
    Yes you can use , What is the Control Voltage and Current you are applying ?
    Jun 2012
    11
    the current and voltage are maximum that the mp4104 can deliver, by the way i have tested it (i've removed the 4 tip122 & replace theme with one mp4104 following the datasheet but nothing happens) i thing that the broblem was the 4 bc337 were not delevering enought power to switch on the mp4104 , i trayed hooking it directly to the pic i/o & it worked perfectly but no microstepping ,,,is there a solution for doing that with microstepping (i'm not experienced in electronics) & what pieces will i change to do it,,,
    thanks a lot for replying
    May 2005
    1397
    Roman would know better, than I because I am not an analog electronics person, but I don't believe the microstepping will ever work as expected with those transistors because they do not have the same response curve as the TIP122. You can see this in the datasheets:
    http://www.fairchildsemi.com/ds/TI/TIP122.pdf
    http://www.semicon.toshiba.co.jp/inf...type=datasheet
    The curves are very different, and the Linistepper code and D2A converters are designed for the TIP-122.
    What is your actual goal and perhaps we can provide you with a better solution?
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Jun 2012
    11
    thanks james for replying, my purpose is to design a microstepping driver based on the mp4104 ,i wish i can find some solutions (i'm not expert in electronics) ,i'm sure it can be done with some modifications in electronics components.
  1. Eagle PCB array?
    By stk2008 in forum PCB milling
    Last Post: 03-21-2011, 07:05 PM
  2. Pin array
    By sp1nm0nkey in forum Mastercam
    Last Post: 07-05-2009, 03:27 AM
  3. Array with v20
    By DEW in forum BobCad-Cam
    Last Post: 11-21-2007, 12:50 AM
  4. LED array sequencer
    By MrWild in forum CNC Machine Related Electronics
    Last Post: 11-21-2006, 06:31 PM
  5. Toshiba Transistor inverters
    By Stevie in forum CNC Machine Related Electronics
    Last Post: 02-28-2005, 09:56 PM
