Some oils do not mix well with others (grades and makes) and will "snot." As mentioned above these are not check valves but metering units. They create a back pressure so a precise amount of oil gets to all points. Without these metering units the oil would go to the point of least resistance and your machine would suffer.
You can try soaking them in carburator cleaner and clean the lines and tank as well. A MOBIL vactra number 2 is a good way oil to use and can be purchsed at grainger.
If this soaking does not help, you will have to replace them.
George
