587,006 active members*
2,845 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Chinese 6090 router with DeskProto problem
    Feb 2007
    31
    I have a Baileigh WR23 cnc router.It is a rebadged Chinese 6090. I can't say exactly which one.
    It has the RZNC-0501 HBBC usb hand held control. I tried to use my stl files with DeskProto.
    They seem to be ok on the usb drive,but the controller can't see them. The drive is a 512 mb
    with fat 32 format. Iso files just don't seem to work.
    Also the onboard files seem to work, but the bit is above the board, so it is carving air. I have
    the C.A.D. for adjusting the Z axis. It touches the disk lightly than goes up,but not where it
    shoul be.I have the multi axis version of DeskProto v6
    Feb 2010
    62
    Hi Jeepers,
    I just see that I never responded to this post: sorry about that.
    Is it still current ?
    About the machine not seeing the NC files on the USB: I suppose that it is looking for a different file extension. You can rename the files to find out which, and then in the configurable postprocessor tell DeskProto to use that extension.
    About the carving in air: have you set the same workpiece zero point as defined in DeskProto ?
    Lex.
    Jan 2007
    1795
    what you describing that is the dsp control..
    you can ask your seller, or looking for ebay an ncstudio card for your router, and breakout board...
    that way you can use you hard drive instead a limited memory stick
    SALE CNC Router Milling, CNC Laser, CNC plasma machine, China, Servo Motor Drive, UK, USA, Italy, Spain, Thailand
    another one is the mach control
    if you were using sure the 3 axis only, the ncstudio version better due to it don't using the main processor in your computer..
  1. Chinese CNC Router Problem XJ-6090 PLZ HELP :(
    By 6bx in forum Commercial CNC Wood Routers
    Last Post: 05-05-2014, 07:28 AM
  2. Groupon for KL-6090 CNC router
    By automationtechinc in forum News Announcements
    Last Post: 03-20-2013, 08:42 PM
  3. Replies: 3
    Last Post: 02-14-2013, 05:09 PM
  4. Groupon for KL-6090 CNC router
    By Kelinginc in forum Automation Technology Products
    Last Post: 11-11-2012, 06:50 PM
  5. Kl-6090 CNC router being used as a plasma cutter
    By automationtechinc in forum Automation Technology Products
    Last Post: 03-17-2012, 11:29 PM
