Attachment 185792
After finally getting my machine to the cutting stage it has thrown this issue at me. As you can see in the picture it will be cutting good, then it will move 2-3mm to the left and carry on cutting good again, until it moves another 2-3 mm left.
The step isn't always in the same place, i have tried different feed rates but the step is apparent sometimes during the cutting ( on other cuts as well, but not all the time ). I have recalibrated and all is well.
Is this the kind of issue you get with the cheap ebay controller cards as that's what I'm using . I have bypassed the opto isolators but had no affect.
is there a way to prove / disprove the card?
thanks in advance for the help and at what stage do you finally stop watching the machine cutting.
thanks.
