Ok so now I've got almost everything wired. Only things left are the limit/home switches. As I understand it, it is preferred to use the NC circuit for the limits and the 3 NO circuits on the Negative side of the Axis as the home. So I've got all the wires coming back to the BOB (Longs Chinese Special) and need to make the connections.
On 15 I've got the Estop. 13 X Axis Limits NC, 12 Y Axis NC, 11 Z Axis NC, All Home wires go to 10 NO. And then just assign in Mach3 to match. Does this sound right?
Also, is the Jog speed approximately the same as max travel (Rapid?) speed of the Axis? Or is Mach 3 just protecting me from Jogging into the hard stops by keeping things slow?
