Can anyone help me with X6 high speed surface paths? Seems to be quite different than the standard surfacing toolpaths.
I have an issue where the tool wants to roll over the edge of a surface. If I try to select a check surface but some toolpaths don't support check surfaces and others treat check surfaces as drive surfaces.
I could also make a boundary which seems to be the only option but to me is a pain in the butt and not very time efficient. I know in the standard surface toolpaths you could select this option (only between surfaces etc.) just wondering if there an option like this in the high speed surface toolpaths
Thanks in advance
