587,035 active members*
3,028 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > using cutter comp
    Jan 2010
    62
    using cutter comp
    how do we go about using cutter comp? G41 and G42 and if someone could put up a sample program that would be great!
    Dec 2008
    4548
    Cutter comp is a "machine" command. You setup the toolpath offset at the machine. Just make a single circle, then add a profile and on the patterns tab, select the machine compensation. The G41/42 will only output in the code when you select a lead in/out "other" than vertical.
  1. Using cutter comp eia/iso on M2
    By apylus444 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-22-2020, 03:14 PM
  2. cutter comp in G91
    By KEENANDOG1 in forum Haas Mills
    Last Post: 10-08-2011, 08:40 PM
  3. cutter comp help please!
    By metlcutr55 in forum G-Code Programing
    Last Post: 02-25-2009, 02:50 PM
  4. Cutter comp on an id hole< cutter diam.??
    By PaintItBlue in forum Haas Mills
    Last Post: 05-06-2008, 12:30 AM
  5. cutter comp in eia
    By mrwright in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-21-2007, 01:53 PM
