586,460 active members*
3,158 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Apr 2007
    161
    Quick Question
    Once the board is built can you still check the 5v circuit? Right now I have issues with my board per my previous post. I have a near dead short between the main negative terminal and the +5v pad. It only has 1.5 ohm. Can someone with a fully built board just measure the resistance between your main negative terminal and the +5v pad? I need to know if this is normal or not?
    Apr 2007
    161
    Anyone?
    Thanks,
    Jason
    Dec 2003
    24223
    In the absence of a schematic and support for the board, it comes down to reverse engineering usually being necessary!!
    Al.
    Albert E.
    Aug 2010
    15
    I have had this board soldered up for about a year now and I am just now wiring up the power supply. I did check the 5 v test per the instructions before I stopped working on it. I can check tomorrow evening.
    Apr 2007
    161
    That would be fantastic,
    Aug 2010
    15
    I measure 512 ohms across the ground and 5V pad.
    Apr 2007
    161
    Yeah I only have 1ohm so that is an issue.
    Sent from my SPH-D710 using Tapatalk 2
    Aug 2010
    15
    Maybe a bad 5v regulator??
    Apr 2007
    161
    That was my thought. They got really hot, really fast with only 12v. I am in process of removing the regulators. I have already removed the left one and the middle one, but still have one more to remove. I just have to remove the LM-317HV. Hopefully that is where the problem is. Once i remove it, there should be no connection between the 5v pad and the neg terminal... I believe, if it is the problem. If not then i am in trouble, because i have no idea where to go from there.
    Apr 2007
    161
    Well I am lost now. I removed all of the regulators and I still have the dead short on the 5v line. I don't know what part would have gone bad to cause the short. Nothing on the board looks damaged. I really need a diagram of the board or something. I am lost at this point.
    Nov 2009
    4415
    Are you a member of Dave's Yahoo group? There used to be a pretty active group for the HCNC boards.
    A lazy man does it twice.
    Apr 2007
    161
    Yeah and i posted it there but nothing... Nearly no help. Dave is no where to be seen. I posted there 12 days ago.
    Thanks,
    Jason
    Nov 2009
    4415
    He does expect you to read a lot. I like the product once up and running. I do remember the frustration of being new to all if this. Once I passed all of the electrical tests and hooked up my machine, a whole new education was needed to figure out what to do to make the machine move. Mach configurations, MDI, GCodes, Hotkeys. I still know nearly nothing.
    Apr 2007
    161
    I have read back to 2008. I have searched for the same problem and found one or two that are close. I have eleminated them as the problem. At this point i just have to start removing parts till the short goes away. I am having issues removing the chips. Without a desoldering station i dont think i can remove them. The lack of support for this product bothers me. Without a diagram of the board i can't find where the short is happening.
    Thanks,
    Jason
    Apr 2007
    161
    Ok i have narrowed down the short to the Y axis. I have a short to the Y vref pad. I have removed the chip between the x and y, the variable resistor, and both caps on the Y. The short is still there. I did a resistance check of the driver chip and it matches the others. Ahhh
    Nov 2009
    4415
    At least you are making progress in your diagnosis. Still no help on the yahoo site? I wish I could help, unfortunately with my advice you would
    likely chase more shorts ;-) Good luck and keep us updated on your progress and eventual solution.
    May 2010
    313
    I dont know if this will help, how accurate it is, or if it will be any help.
    But I found this in a post about modifying the board.
    John
    Apr 2007
    161
    Quote Originally Posted by WoodSpinner View Post
    John
    Thanks that is very helpful. I should be able to show that to one of my guys at work. I can muddle my way through electronics but I am not great with advanced stuff.
    Apr 2007
    161
    Quote Originally Posted by lucas View Post
    That short on the Y Vref is a good indication.
    I would guess that the Y driver chip is shorted internally and pulls both the Vref and +5 down.
    You could compare the resistance of all chip pins with each other, if one or more pins of the Y chip is different then it's probably blown.
    To be sure you could cut the 5V pin of the chip or the PCB trace to that pin (do it in such a way that you can resolder them back) and then measure again.
    What supply did you use, you mentioned 42V IIRC, this may be on the limit.
    Ok, I have removed the y-axis driver chip. The resistance at the y-vref is no longer shorted. With chip removed I now have 20k ohm. So, the y chip was bad. I still have a short on the 5v line and I am suppose to 512 ohm. The 5v tab has two path ways, I am going to break one of them and start tracing in the other direction. I have made several things to help me trace it. I have some helpful photos on my photobucket page located HERE
    364
    512 ohm between 5V and ground is NOT a short, there could still be a too high load but I'm quite sure this could be OK.
    If you still can: measure the resistance on the removed chip between the 5V and gnd pin.
Page 1 of 2 12
  1. quick question.
    By Willfitz in forum Canadian Club House
    Last Post: 02-29-2012, 12:34 AM
  2. Quick Little question
    By Clawsie Machine in forum Mastercam
    Last Post: 01-09-2008, 01:20 AM
  3. New here, quick question 2T on TC-2
    By RonRoy2004 in forum G-Code Programing
    Last Post: 11-07-2005, 04:16 AM
  4. really quick question:
    By bigal in forum CNC Machine Related Electronics
    Last Post: 06-22-2005, 01:39 AM
  5. Quick V18 Question
    By Edster in forum BobCad-Cam
    Last Post: 12-13-2004, 04:53 PM
