586,058 active members*
4,101 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Not good at math OR scale is all wrong
Results 1 to 8 of 8
    Mar 2013
    81
    Ok so I'm not good at math. Built a fixed gantry 3 axis MDF machine. Got everything together and running. Noticed a funny thing while testing travel versus coordinates. Everything in gcode is about 1/10 actual size.
    My fix was to change the pulse per increment in Mach 3 from (calculated) 2000 to 22000 on each axis. That seemed to dial it right in. But obviously I've done something wrong along the way. Is this just another newb error? If so, what might I do to correct it?
    Apr 2005
    253
    Maybe check your controller micro step setting
    I'll get it finished sometime after I start it.....
    Mar 2013
    81
    Quote Originally Posted by robe_uk View Post
    Right. That's what I thought. I have the DIP switches set at 2000. These are the Longs DM542A controllers.
    Jun 2004
    6618
    Okay. There is some math involved. If you are using Mach 3 and have a dial indicator, you can eliminate most of the math. There is a button on one of the pages that lets you calibrate each axis. This is needed even when you do the math. There are screw errors sometimes and the math just isn't quite accurate enough.
    I have used this method to calibrate each axis on every machine I have with great results.
    Just a gloat, I have 6 working right now. That is if I include the 3D printer.
    Let us know if you need more help with it. These cnc machines are only as accurate as your calibration.
    Lee
    Apr 2005
    253
    Quote Originally Posted by Michaelofburien View Post
    Ok, what type of drive? Screw or rack and pinion? A screw might be 10 turns per inch (roughly) which would account for the steps you are seeing, again please post more info of your setup.
    Mar 2013
    81
    Quote Originally Posted by LeeWay View Post
    This was going to be my next step if I didn't hear a good answer here. So I'm kind of glad to hear my assumptions are pointing me in the right direction.
    10 TPI ACME screws all 3 axis. It is highly likely that I have the DIP switches set wrong.
    Jul 2009
    690
    Some chinese drivers' dipswitches are counter-intuitive and use 1 as OFF and 0 as ON, maybe that's the problem and you have the switches inverted?
    http://www.build.cl
    Apr 2007
    8082
    Leeway is correct.
    It's on the Alt-6 Tab, just above the RESET button. You can get very close using this utility, then edit the last few digits of the number manually until the actual cut measurements are as close as you need them to be. Record the x/y/z steps per unit numbers somewhere for future reference. This corrects for any tolerance build-ups in the parts, but don't rule out that there may also be some backlash involved that need to be corrected or accounted for.
    CarveOne
    http://www.carveonecncwoodcraft.com
  1. Replies: 4
    Last Post: 12-26-2023, 06:54 PM
  2. Good small scale, complex projects
    By xander18 in forum MetalWork Discussion
    Last Post: 06-23-2011, 04:16 PM
  3. Corel Draw HPGL wrong scale in KCam
    By waleed alhadidi in forum Uncategorised CAM Discussion
    Last Post: 01-29-2010, 08:35 PM
  4. Scale math formula ?
    By timmydabull in forum Mastercam
    Last Post: 08-31-2008, 05:50 AM
  5. Need to make scale tire mold for 1/6 scale car
    By thuffner3 in forum Moldmaking
    Last Post: 04-29-2008, 06:57 AM
