Does anybody know if it is possible to pattern a model
like you can pattern a sketch---or any way to create
a model and then reproduce it two more times in the
same window?????
same window?????
You can use Translate or Rotate to do that.I would suggest a quick read of the Help files ,as to how to set-uo for your particulars.And take a look at the "LINKS" thread I just started.
