586,102 active members*
2,947 visitors online*
    May 2013
    i can't find anywhere end mill cutter like this
    Hello, i'm from poland and sory for my english.
    i looking for end mill cutter like this:
    Attachment 186182
    Attachment 186184
    with diameter mounting 4mm and diameter of cutter 0.6mm for cutting in silver and gold. Somebody knows where can i buy it, couse i can't find it in any shops?
    Thanks for help,
    Paul
    Jan 2006
    2985
    Apr 2012
    63
    Apr 2012
    63
    10pcs 4mm double flute ball nose end mill for steel and copper, round nose spiral bits
    This one is ballnose end mill, your picture is very small, I can not see whether it is ball nose.
    However, if it's flat head end mill with 0.6mm cutting edge, it might be not stronge enough.
    CNC routers and accessaries
    www.tayoutec.com
  1. Where to find 30 degree dove tail cutter?
    By Rich05 in forum MetalWork Discussion
    Last Post: 09-20-2010, 09:56 PM
  2. Rack and worm cutter trying to find
    By callcbm in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 03-16-2010, 03:58 AM
  3. Where to find Shell mill / Face mill arbor for taig
    By 725franky in forum Taig Mills / Lathes
    Last Post: 11-18-2009, 11:48 PM
  4. Trying to find a specific type of cutter
    By Airassault in forum Want To Buy...Need help!
    Last Post: 03-20-2009, 10:16 PM
  5. Slot Cutter Holder Arbor type, cant find??
    By mgb1974 in forum MetalWork Discussion
    Last Post: 03-10-2008, 01:36 PM
