586,051 active members*
3,590 visitors online*
Thread: Spoil board
Results 1 to 6 of 6
    May 2011
    65
    Spoil board
    Hi, what are you guys using to surface your spoil boards? I am using a porter cable router that can only accept up to 1/4" shanks. Also do you simply jog your cutter across and back to obtain a level surface or is there a simple program that will do the job?
    Thanks for any help you can offer.
    Terry
    Regards, Terry Howson
    Apr 2011
    121
    I used a 1/4" router bit because that is what I had. A fly-cutter would be better, but finding one in 1/4" shaft is problematic and likely expensive.
    I made a simple rectangle part the size of my working area and used that as a surface for my CNC software to surface. I forget the specifics of how I did that though.
    Nov 2007
    483
    Try using the largest dado router bit you can find for 1/4". I'm sure you can get one super cheap on ebay. You just need to create a pocketing tool path the size of your spoil board. I use Cut2d which makes creating the tool path super easy. It's an easy shape so you could program the tool path manually.
    May 2011
    65
    Thanks for the replies, I thought this was the way to go. I have made flycutters for my Sherline mill so should be able to make one with 1/4 shaft.
    Terry
    Jan 2006
    2985
    Quote Originally Posted by skylanehku View Post
    Terry
    I would advise against doing that. A Sherline at 2000 RPM and a router at 20,000 RPM will behave very differently with an unbalanced tool in the spindle. I'd guess something is going to go flying.
    You can get a 3/4" cutter with 1/4" shank here: http://www.rockler.com/product.cfm?page=5724
    Matt
    May 2011
    65
    Thanks Matt I will get one.
    Terry
  1. Spoil board cutter?
    By mafitch7479 in forum Commercial CNC Wood Routers
    Last Post: 08-24-2011, 04:37 AM
  2. Surfacing the spoil board
    By Rickv100 in forum Commercial CNC Wood Routers
    Last Post: 10-31-2009, 08:28 PM
  3. What is the purpose of a spoil board?
    By j_wizard in forum CNC Machining Centers
    Last Post: 10-28-2009, 03:18 AM
  4. Spoil Board
    By lfourtner in forum Commercial CNC Wood Routers
    Last Post: 12-15-2008, 07:40 PM
  5. Resurfacing spoil board
    By avccrml in forum WoodWorking Topics
    Last Post: 08-12-2007, 02:01 PM
