586,108 active members*
3,038 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Water cooled spindle, what coolant do you use
    Oct 2005
    58
    I have been looking on the web for a Tig welder to weld the aluminum gantry parts when I came across this link:
    Coolant for TIG welding - WeldingWeb™ - Welding forum for pros and enthusiasts
    They were discussing the water additives for a water cooled tig torch. There was a lot more to consider than I had
    thought! I said to myself that many of the things mentioned in the posts were applicable to a water cooled spindle
    coolant as well. So if you plan to use a water cooled spindle take a look at the URL and possibly save yourself
    some headaches down the road.
    I do not know why you cannot click on the URL above, but just cut and paste it into your browser.
    Dec 2004
    783
    Friendly bunch over there...
    I used kid/pet safe antifreeze and purified water, real tygon lab grade tubing and made sure to only have aluminum parts in the system. Nalgene expansion tank.
    Haven't touched it in over a year, no problems, It's away from sunlight and mostly shaded from florescent light so no real worry about algae.
    A flow sight gauge is nice for peace of mind to make sure the pumps running at a glance.
    Sent from tapatalk
    Aug 2011
    999
    I plugged the fluid ports and use external dust extractor air flow to cool my Chinese "water cooled" spindle. Gets rid of a whole bunch of cumbersome plumbing junk and works absolutely perfect for over a year now. I dare say the cooling efficiency is probably higher than for the usual water trickle. I find the spindle temp is mostly 5-10 degrees above ambient for a 2.2kW spindle. At full load maybe 20 degrees or so but I rarely have that.
    For comparison:
    - a water flow of 20 gallons per hour (I believe recommended for the spindles) has a heat dissipation capacity of 317 kilojoule per hour and degree Kelvin
    - an air flow of 30,000 cubic ft/hour (typical for a 1 hp dust collector blower) has 916 kilojoule per hour and Kelvin
    I am not sure about the convective heat transfer comparison but with the much larger outside surface area (compared to the tiny liquid channels) and the way higher velocity I guess it is also at least as good for air.
    Nov 2009
    4415
    I run tap water through my tig torch with no negative results. I run city pressure and the flow would be much higher than 20 gallons an hour.
    A lazy man does it twice.
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  3. Should I refrigerate my water cooled spindle coolant?
    By davtuner in forum DIY CNC Router Table Machines
    Last Post: 02-09-2012, 06:56 PM
  4. Water Cooled Spindle
    By sylvan in forum CNC Tooling
    Last Post: 09-03-2011, 12:20 AM
