586,106 active members*
3,303 visitors online*
    May 2011
    65
    Another modified Momus
    Hi, I am almost finished my build, I elected to go with a steel frame of rectangle and square tube, mig welded together. The rest is pretty well as per Bob's excellent plans. My spoil board will be held with the clamps shown and the work attached to the spoil board. It will be run with Mach 3 and a Gecko 540 controller.
    Terry
    Regards, Terry Howson
    Mar 2013
    209
    This is awesome!
    I wish I knew how to weld steel at that accuracy. :-)
    If you can get that thing to work, it'll cancel all other wood movement inaccuracy/flex problems out and you'll have a fine CNC router. :-)
    Keep posting, this is very interesting.
    Mac
    Aug 2006
    132
    +1 with Mac.CNC this is an excellent variation on the theme.
    I bet it weighs less than mine too.
    I like the single panel swing down and that might be a good variation for the wood based Momus also. Rather than the oval hole in the between member, a couple of 'U' cutouts for wiring to cross the swing panel would do fine.
    Well done and congratulations!
    -=Doug
    "IT ≠ IQ " Starwalt 1999
  1. FreeRiders V-Bearing Modified Momus
    By FreeRider in forum Momus Design CNC plans
    Last Post: 12-24-2015, 06:59 PM
  2. Sven's modified Momus build thread
    By svenw in forum Momus Design CNC plans
    Last Post: 11-27-2012, 06:24 AM
  3. G76 Modified Threading
    By lathe_man in forum Hardinge Lathes
    Last Post: 04-29-2010, 12:25 PM
  4. Modified JGRO
    By ZOB in forum Commercial CNC Wood Routers
    Last Post: 05-13-2007, 04:48 PM
  5. Modified JGRO
    By ShayArnett in forum Commercial CNC Wood Routers
    Last Post: 05-06-2006, 02:33 AM
