586,119 active members*
3,460 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > arrow 1000 spindle won't align
    Mar 2008
    114
    Hello all
    We recently acquired an arrow 1000 with the a2100 control. It powers up ok and begins to align all 3 axes but won't align the spindle - comes up with alarm 39-81 spindle drive not responding. I checked and the resolver feedback on the motor seems to be working - when i rotate it by hand I get a positive or negative rpm feedback on the control screen. the spindle drive is a vickers acramatic vector 2604a and the sys ok , cpu, & relay L.E.D.s are all green. the fault L.E.D. is red. According to the previous owner the spindle drive was sent away for repair and it still has a warranty seal tag on it. At this point I suspect either a problem with the motor or the I/O board/relays on the enable signal channel. Does anyone have any ideas how to isolate this problem further?
    Sep 2010
    1765
    the fault lite is red: 100% means the vfs5 drive has or sees a problem. unless fault lite is off it will not run. see if u can send it back to the place who put the seal on it. if you cannot, feel free to call us for free phone help.
  1. Arrow 1000
    By Dixieplastics in forum Cincinnati CNC
    Last Post: 03-13-2012, 01:37 PM
  2. Arrow 1000 not powering up
    By Arrow eeyore in forum Cincinnati CNC
    Last Post: 01-26-2012, 08:51 AM
  3. TPA Question Arrow 1000
    Last Post: 05-19-2010, 03:59 PM
  4. Arrow 1000 spindle trouble
    By raygun in forum Cincinnati CNC
    Last Post: 03-03-2009, 04:32 AM
  5. trouble to align cincinnati arrow 1000 (1998)
    By aherrc in forum Servo Motors / Drives
    Last Post: 03-08-2008, 12:16 AM
