586,069 active members*
3,363 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Simulation visibilities
Results 1 to 11 of 11
    Jun 2006
    3063
    Lately, when I simulate with SC7, the material removed during an operation is not displayed as removed until the operation completes. Previously, it would show an appropriate amount of material removed on each pass in the simulation. This has happened before and I figure that it is either caused by an errant mouse button press on my part or by SC randomly changing settings on its own. I tried changing visibility of the different features in various combinations without success and finally hit on this one:
    Attachment 186610
    Is this the setting most others use? Are any others having trouble with the visibility settings getting changed on their own?
    Mike
    Feb 2008
    389
    Hi Mike,
    For a while now I have been clicking on the "Reset Workpiece" button (the red X) before running a simulation. Especially after going from the machining tab directly to the simulation tab.
    The various visibility selections with all their options sure is confusing tho
    These are my visibility selections in the simulation tab...
    Attachment 186658
    Currently using SC7 Build 1.6 Rev. 64105
    Jun 2006
    3063
    Thanks Gerry. I hit the "Reset Workpiece" button regularly too, so I don't think that's it. I suspect that either SprutCAM 7 is flaking out on it's own or I'm inadvertently hitting some shortcut key that changes something that affects visibility. My bet is SC flakiness. Sometimes the simulation never actually shows the effect of cutting and sometimes it does, but only at the end of the op. For example if 3 holes are being drilled the cavities for all 3 holes will stay filled unto the drilling op completes and then all 3 cavities are revealed simultaneously.
    I'm reluctant to switch to SC 8, but maybe that has gotten better. IAC, Sprut probably won't be fixing any remaining SC 7 bugs, so maybe it would be better to switch.
    Mike
    Nov 2010
    360
    Quote Originally Posted by MichaelHenry View Post
    Mike
    Its Sprut flakiness. It has been doing this for me for the last 3 releases or so.... Not a show stopper, but certainly annoying.
    Jun 2006
    3063
    Quote Originally Posted by dbrija View Post
    Thanks for confirming. Flakiness seems to be the most likely culprit for most Sprut woes.
    Mike
    Feb 2008
    389
    Mike
    I try to check their web site out every 3 or 4 weeks to see if there is a newer version and the engineers in Russia still seem to be uploading newer versions.
    The most recent was uploaded on 5/21/2013 and the one before that was 4/16/2013.
    I'm currently using the version that was uploaded on 5/21/2013 (Ver 7.1.6.64105).
    Here is that web site if you don't have it...
    Download.SprutCAM.com
    Jun 2006
    3063
    Quote Originally Posted by Gerry Sweetland View Post
    Thanks Gerry. I ran into the disappearing simulation again last night on a simple project and discover that the type of simulation chosen made a difference. I'm not at my CAM system now, but the 1st of the 3 simulation types simulated correctly and the latter two didn't.
    Thanks for the download link - I keep losing the good one and finding only old (bad) ones. I'll bookmark that one.
    Mike
    Feb 2008
    389
    Mike
    You're welcome Mike.
    I used to try and do all my simulation in Voxel 5D but I soon learned I didn't have as good a computer/video as I wished (thought) I had. So I use Voxel 3D most of the time, especially on projects with more than 8 or 10 operations in them.
    And I have noticed that if I am doing some experimenting, trying different ops w/ different settings and simulating and re-setting, running, etc. my graphics seem to suffer and I need to restart SC to clean out the memory or something.
    I bought a new video card a few weeks ago, a ATI FirePro 4900 along with a new power supply to run it and was somewhat disappointed that it did not improve the graphics in SC that much. However, it did improve my SolidWorks graphics substantially.
    I have a 64bit system with a quad core CPU so I'm hoping that if I do upgrade to SC8 64bit I'll see a substantial increase in performance with running operations AND graphics?
    Nov 2010
    360
    Did you go into "System Setup" and crank up the settings under "Visualization"? There are several tunable settings like "Animation", "Perspective", and "Visualization Quality". In fact, playing with these may even fix the stock removal bug... I may play with this.
    Feb 2008
    389
    Yes, I have played around with "Visualization Quality", cranking that up to max only made the system run slower. I run it about 3/4, seems to be the best compromise on my current system. I think "Animation" just affects the speed when changing views, lower or off is faster and up all the way is slower, or you can see the part move to a new view as opposed to just instantly switching views.
    "Perspective" is one that I have not played with but I know if you check the box for it and turn it on it does weird things to the way your mouse works as well as few other unusual results on the screen. Read this thread for more info http://www.cnczone.com/forums/sprutc...se_offset.html
    Jun 2006
    3063
    I'm running an HP Z400 workstation with Xeon 3 GHz CPU, 10 GB RAM, and an NVidia Quadro 600 video card. It seems reasonably fast to me, though the simulations can bog down at times, especially when I've been working a while. Right now, all of them (solid, Voxel 3D, and Voxel 5D simulations) seem to run about the same speed, but only the Voxel 3D actually simulates stock removal during the simulation.. I'm on SC Build 7.1.6.59340 so quite a bit older than the current release.
    Mike
  1. Simulation Done Right
    By jrmach in forum BobCad-Cam
    Last Post: 04-18-2013, 03:05 AM
  2. 5.0 Simulation bug?
    By declanhalpin in forum MadCAM
    Last Post: 03-10-2013, 06:40 PM
  3. Simulation
    By rckdef in forum BobCad-Cam
    Last Post: 02-04-2013, 07:12 PM
  4. v25 Simulation
    By aldepoalo in forum BobCad-Cam
    Last Post: 01-15-2013, 09:38 PM
  5. Simulation only ?
    By patrickb in forum FeatureCAM CAD/CAM
    Last Post: 05-27-2006, 02:01 PM
