586,630 active members*
2,431 visitors online*
Results 1 to 9 of 9
    Nov 2012
    Mazatrol T1 Parameters
    Hello,
    I have a Mazak Slant 40N Universal 1000 with a Matatrol T1. The battery died and the
    parameters were lost. Does anyone have these parameters.
    Jim
    24223
    I have some parameters and the definitions for SL-40, maybe not for that particular machine. If you need send a PM with email add.
    Al.
    Albert E.
    Dec 2007
    300
    If you are lucky there is a hard copy of the machine parameters in the electrical cabinet. Some of them are machine specific so inputting just any number will usually lead to more trouble.
    Feb 2013
    13
    Re: Mazatrol T1 Parameters
    Hello Al, im sorry to bother you, i have a mazak Slant turn-15 with mazatrol T-1 control, the machine starts up fine, and moves all the axis, and i can jog the spindle, but im getting an alarm 130 spindle run inhibit, when i try to spindle start, this is the only thing stopping me from puting it to work, i have checked in a thread you have a list of parameters, i was thinking if you still have it, maybe i can compare them to mine, to see if i got somethings wrong, or maybe you have an idea of what its not letting me start the spindle fully, i appreciate your time and atention, thanks a lot.
    Trill.
    24223
    You will need to PM me an email add.
    Al.
    Albert E.
    Feb 2013
    13
    Al.
    Your inbox is full! [email protected]
    24223
    They're sent.
    Al.
    Albert E.
    Feb 2013
    13
    They're sent.
    Al.
    Thank you Al!
    Hi Al, thank you for the parameters, i have cross referenced them with the ones i have, they seem pretty much the same, do you have any idea why this
    130 spindle run inhibit alarm is happening, here is a video if you would like to see it about the machine:
    Ver 130 Spindle Rotate Inhibit en YouTube
    130 Spindle Rotate Inhibit: http://youtu.be/_jcVV0S3tac
    Thanks for your time.
    24223
    Check out the spindle motor, brushes and brush gear for carbon build up etc.
    Al.
    Albert E.
  1. Need Parameters Mazatrol T1 Controller.
    By weblogictech in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-16-2020, 08:32 PM
  2. Mazatrol M2 parameters
    By pcreek in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-16-2017, 06:06 AM
  3. Mazatrol T1/M4 parameters
    By Carter in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-25-2012, 03:58 PM
  4. Mazatrol CAM T4 parameters
    By active-precision in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-05-2008, 07:19 PM
  5. Parameters list for Mazatrol M2
    By kotten1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-17-2008, 08:10 PM
