586,530 active members*
3,016 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 11m Keyboard certain buttons not working
Results 1 to 7 of 7
    Jun 2013
    3
    Have a Mattsurra 1800h mill with a Fanuc 11M.
    Came in the morning and noticed certain buttons did not work on keyboard. (7,8,9, cancel, cursor, page, B, +,....)
    On this machine there are two 3 segment leds that display tool in spindle and tool in changer. These displays now alternate flash between
    all zeros and the correct tool number. Those displays are machine specific.
    Home position lights will not come on either but machine shows its home in position page.
    Machine will run a program and tool change just fine. Just cant enter or maneuver via certain keys on keypad.
    So, seeing how the ribbon cable and wires for display all went to the I/O board in the display panel, I replaced it for $3400 to realize that wasn't the issue. This was after talking to Mattsuura dealer and Fanuc rep.
    So, I took the keypad out and checked all the keys for function with a meter and it checks good.
    Has anyone seen this? Any suggestions?
    Aug 2011
    2517
    if the panel and I/O board are good go further into the bowels of the machine and see what is next in the connection. could be a broken wire somewhere or a chip or something similar on another board. could even be low voltage or missing voltage somewhere in the wiring or on a board causing the problem.
    Apr 2009
    1379
    Does the control use the A20B-1000-0850 crt/mdi controller?
    Jun 2013
    3
    No, it is A20B-1000-0802
    Jun 2013
    3
    Could memory board be the issue? Or parameters?
    Jan 2024
    Quote Originally Posted by Formula 1 View Post
    Iknow it is an old thread but i am sure it is the keys them self. I have this problem on my matsuura 11M. The key "D" for ex seems to effekt other keys and if i make D work the other linked keys begins to funktion again. So a change of the the key modul is the solution i say.
    /Andol
    Apr 2009
    1379
    Re: Fanuc 11m Keyboard certain buttons not working
    one 'stuck' key will affect other keys. A bad keyboard is likely the problem.
  1. 4 buttons not working on control panel
    By sco in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-11-2014, 08:59 AM
  2. Screen4 buttons not working
    By gort in forum Mach Software (ArtSoft software)
    Last Post: 03-10-2013, 11:51 PM
  3. Problem moving steppers with keyboard buttons
    By Richotech in forum Machines running Mach Software
    Last Post: 06-22-2010, 05:19 PM
  4. Interact / TNC145 buttons not working
    By Mike Woo in forum Bridgeport / Hardinge Mills
    Last Post: 04-29-2009, 01:29 PM
  5. Keyboard stopped working??
    By honk in forum Autodesk
    Last Post: 10-25-2006, 12:16 AM
