586,457 active members*
3,270 visitors online*
Results 1 to 7 of 7
    Dec 2011
    49
    RFQ, Shorten Dowel pins
    Shorten 24 dowel pins to 16mm. I can supply 18mm pins.
    [email protected]
    Oct 2012
    22
    Do they need a chamfer put back on the cut end? Or simply cutting 2mm off the end will do? What diameter dowel pin?
    Dec 2011
    49
    Standard 5mm diameter dowel pin.
    No chamfers, just break the sharp edges.
    Aug 2010
    128
    What is the material? Tolerance?
    Dec 2011
    49
    Alloy steel, I can supply the pins. +/-.010 on the length
    Oct 2010
    103
    why not use something already 16mm long.
    McMaster-Carr
    You wont beat 50 pcs for $13 (alloy steel, M5x16mm) having someone cut down longer pins
    Dec 2011
    49
    Because the lead in chamfer on standard pins is too big for my needs
  1. Reamers for locating/dowel pins
    By Brushtec_DB in forum Mechanical Calculations/Engineering Design
    Last Post: 11-18-2011, 11:30 AM
  2. Dowel Pins to the Rescue?
    By webgeek in forum MetalWork Discussion
    Last Post: 07-31-2010, 05:52 PM
  3. Aligning pop-up pins + dowel drilling
    By mechona in forum Commercial CNC Wood Routers
    Last Post: 01-17-2008, 05:02 AM
  4. Dowel Pins
    By Ursine in forum DIY CNC Router Table Machines
    Last Post: 05-27-2005, 01:53 PM
  5. Dowel Pins
    By Mr.Chips in forum MetalWork Discussion
    Last Post: 02-01-2004, 11:00 PM
