I will have to put prox. sensors on a 2 axis system for cutting some parts. I do need .001" precision and steppers aren't closed loop.
I'm new to LinuxCNC and have noticed the greatly different G-code from what I'm used to in CNC.
If I want to do a homing procedure after each cut can I do that in the G code or is it somewhere else.
If you want to share an example THANKS in advance.
Nelson
