586,062 active members*
4,884 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 21t alarm 086 dr signal off
    Oct 2012
    5
    I bought a used Hardinge Cobra 42 lathe with a fanuc 21t control and I am getting an alarm 086 alarm Dr signal off when trying to transmit. Is there a parameter that I can check to see if it is on, and not the PCB? Also if anyone knows which parameters to check the rest of the rs232 setting I would appreciate it.
    Chris
    Sep 2010
    1230
    Quote Originally Posted by cbsr2003 View Post
    Chris
    Hi Chris,
    Error P/S 86 is usually associated with the pin out of the cable being used. In most instances Software Handshaking (Xon Xoff) is used and when this is the case, a Loopback Null Modem cable, so named because the Handshake Outputs are Loopback to the corresponding Inputs on the same device, is used. The Loopback Handshaking gives the illusion of full Handshaking, when in fact there is no Handshaking at all. Following is the cable configuration for Xon Xoff Handshaking.
    If you don't succeed with the following cable pin out and settings and the P/S 86 error persists, check the voltage between pins 20 and 7 at the control; it should be around 12VDC. Pin 6 and 8 are asserted logic 1 by pin 20. If the voltage is less than 3VDC, this will also cause the P/S 86 error.
    Regards,
    Bill
    Loopback Null Modem Pin Out
    Machine Side ---------------------------------- PC Side
    DB25 Male Connector ---------------- DB9 Female ------ DB25 Female
    1 ---- Shield Trace ----------------Not Connected ---- Not Connected
    2 --------------------------------------- 2 --------------- 3
    3 --------------------------------------- 3 --------------- 2
    4
    | Bridged
    5
    6
    8 All Bridged
    20
    7 --------------------------------------- 5 --------------- 7
    Machine Control Parameter Settings
    #0020 =0 (I/O Channel =0)
    #0100
    Bit 1 = 0
    #0101
    Bit 0 = 1 (2 Stop Bits)
    Bit 3 =0 EIA or ISO code (automatically distinguished)
    Bit 7 =1 No Feed (Null Characters) before and after the data at data output (
    #0102 = 0 (RS-232C using Control Characters DC1 to DC4)
    #0103 = 11 (9600)(Baud rate)
    PC Software Settings
    Handshake Method = Xon Xoff
    Data Bits = 7
    Stop Bits = 2
    Parity Bit = Even
    Baud Rate = 9600 (or whatever the control is set to)
    Jul 2011
    Unhappy Similar Issue
    My mill has just started giving me this error. The only thing that happened of any significance was the PC getting unplugged by accident. It was not feeding a program at the time- in fact, the mill was off. We have been running Realterm to drip feed with the same settings and cable for two years now. None of the settings on the control are wrong; baud rate is ok, correct channel is selected, tv check is off.
    I have completed these meter tests and determined the my pin 20 on the control reads 0V, with the PC cable unplugged from the mill.
    What might we check next? All the posts I've seen about this issue seem to result in fixing broken cables. I have tested the cable, tried another cable, even tried another PC that runs other mills with both cables. I manually tested data coming from the serial port on the PC and it is fine. The issue clearly seems to be the mill side.
    Is there a p/s, fuse, error, etc- anything else that I can check? I have checked all fuses on the back of machine, in case some type of power issue was the cause. None of the units in the back appeared to be off but I will be looking it over again.
    Mill: YCM 1040A
    Control: Fanuc MXP 100i
    Thanks.
    Quote Originally Posted by angelw View Post
    Hi Chris,
    Regards,
    Bill
    4
    | Bridged
    5
    6
    8 All Bridged
    20
    #0100
    Bit 1 = 0
    #0101
    Data Bits = 7
    Stop Bits = 2
    Parity Bit = Even
    Sep 2008
    67
    Chris
    hi
    if the communication does not work with the proposal below.
    fanuc 16 18 21 have a spare port, in main board , JD5A = I/O chanel 0 and 1. JD5B = I/O chanel 2 and 3
    you can change the connector JD5 To JD5B.
    and you will SETT the parameters.
    good luck
    Apr 2020
    Re: Fanuc 21t alarm 086 dr signal off
    This seems to be a short circuit problem, can review this technical problem
    cookie clicker 2
  1. Fanuc 3M servo alarm overload signal
    By max_c in forum Fanuc
    Last Post: 09-04-2015, 03:23 AM
  2. OMD 086 alarm DR signal Off when recivieing
    By meadowtech in forum Fanuc
    Last Post: 10-25-2013, 09:32 PM
  3. Replies: 5
    Last Post: 10-12-2013, 02:23 AM
  4. Alarm 10 - No Signal Y-axis
    By mhl827 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-13-2011, 01:37 PM
  5. dr signal off alarm
    By driftbuster50 in forum Daewoo/Doosan
    Last Post: 07-23-2010, 07:21 AM
