586,069 active members*
3,379 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > What material to use for a platform that holds 300-500 lbs?
    Jun 2013
    I am making a flat platform with 4 leveling feet that can hold a 300-500 lb fan. It is around 24" x 24". Do you guys have any suggestions on what material I should use and how thick?
    Apr 2013
    89
    Any pictures of the fan?
    Can you show a drawing of what you have in mind for the base design?
    Ji
    Grip It & Rip It
    Jun 2013
    Quote Originally Posted by Jigantor View Post
    Ji
    I am making a flat platform with 4 leveling feet that can hold a 150 lb Corrosion-Resistant Heavy Duty Blower plus another 150-350 lb (so in total 300 - 500 lbs of mass).
    Also if I wanted to reduce the vibration from the fan would it be a good ideal to put a layer of rubber on the platform?
    This will be indoors and will be a raised platform, I was thinking of using the Heavy Duty Vibration-Damping Leveling Mounts.
    So overall, this is what the whole system should look like.
  1. I need a starting platform.
    By Fuelrush in forum Benchtop Machines
    Last Post: 03-06-2011, 02:26 AM
  2. X3 32 Bit on 64 Bit platform
    By foxsquirrel in forum Mastercam
    Last Post: 07-10-2010, 08:14 AM
  3. Marking pen or paint pen that holds up to coolant?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 11-07-2007, 05:55 AM
