587,011 active members*
3,857 visitors online*
Page 10 of 25 8910111220
Results 181 to 200 of 493
  1. #181
    May 2014
    9
    Re: X61500GT - New CNC-Carving Router
    Hi everyone
    Does anyone know of a dust shoe that i can buy that will be compatible with the x6-1500GT ?
  2. #182
    Mar 2013
    319
    Buy no, but I designed this the other day, just need some magnets to finish it off.
    Seems to work great so far.
  3. #183
    Feb 2014
    103
    Wow! Nice work guys!
  4. #184
    May 2014
    9
    WOW! That's amazing! Looks so professional.
    Do you have the details if how you built it? What material did you use? How difficult was it?
  5. #185
    Feb 2014
    103
    Quote Originally Posted by calldrop View Post
    I'm interested in where you got the brush material and how you fastened.
    Calldrop. The Red seems to be 3d printed ABS plastic. The clear is acrylic. Looks fairly simple if you have a 3d printer or know someone that does! Im sure a few of us wouldn't mind printing them out for you if you have a design or zeeflyboy would be kind enough to share his.
    I could design and print one if you are in the US.
  6. #186
    May 2014
    9
    Wink Re: X61500GT - New CNC-Carving Router
    Quote Originally Posted by Stevos758 View Post
    Thanks Stevos758 for the info I'm unfortunately not in the US I live in Dubai (pretty far away) ... but I do have access to a 3D printer
    If "someone" could share the design files, that would be amazing + much appreciated
    on a different note, does anyone have the script to control the Z axis Auto Tool Zero - I tried to used some generic scripts I found on other forums, but with no luck? That will be so good if I could get it.
    thank you.
  7. #187
    Mar 2013
    319
    Exactly, red parts are 3D printed ABS, clear is just acrylic I did on the CNC.
    I'll be happy to share my design, though of course it's designed to fit my specific shop vac nozzle. I'm travelling today but will post a link later or in the next couple of days.
    I'll also post where I bought that brush at the same time because I can't remember off hand. It has a rubber strip which actually works fine just as a push fit, you could easily add some glue to help hold it in place if you wanted.
  8. #188
    Feb 2014
    103
    thank you.
    I'll work on something and get back to you.
    I do have a working auto zero script I found online. Attached autozero script. Just edit button scripts and open it in the editor.
    BE SURE TO CHANGE YOUR ZERO BLOCK HEIGHT! zoffset at the top.
    https://www.dropbox.com/s/flz6qxow14ztgyn/Autozero.m1s
  9. #189
    May 2014
    9
    Thanks a million zeeflyboy
  10. #190
    Feb 2014
    103
    Quote Originally Posted by zeeflyboy View Post
    Yes! Thanks Z!
  11. #191
    May 2014
    9
    Thank you so so much Stevos758
    I'll try it out and let you know how it went.
    thank you
  12. #192
    Feb 2014
    103
    thank you
    No problem! It changed my life when I got that script set up! It's nice! Saves time and guess work if you don't have the proper tools.
  13. #193
    May 2014
    9
    Thank you! Thank you! Thank you!
    It worked perfectly! This is so much better than spending almost an hour trying to figure out Z0 every time I change the drill bit.
    Thank you Stevos758
  14. #194
    Feb 2014
    103
    Thank you Stevos758
    No Problem! I felt the same way when I got it working!
  15. #195
    Feb 2014
    103
    Anyone happen to 3d model their machine? I am looking to build a stand for it. Just curious. Would save me some time.
  16. #196
    Jan 2014
    13
    Hey all,
    I am wondering about a maintenance of the machine.
    What do you do and how often?
    Lubrication comes to mind, but I am not sure how to do it and how often. Does anybody have better idea?
    M.
  17. #197
    Mar 2013
    319
    So guys, sorry for the delay but here's all the files and instructions you need, link to the brush section is also in the instructions.
    Magnetic Dust Boot for 1.5kw water cooled chinese spindle ( e.g. X6-1500GT) by Zeeflyboy - Thingiverse
    This is my latest version with some tweaks
  18. #198
    May 2014
    9
    [IMG]
    Thanks a lot zeeflyboy, I'll print it out (might resize the vac nozzle though).
    This is going to really reduce all the dust coming off my cuts
    Thanks again !!
  19. #199
    Feb 2014
    103
    Thanks again !!
    Yes thanks! I just finished my cart and moved my machine to the garage!
    Much nicer to work on out there!
  20. #200
    Feb 2014
    103
    Can anyone recommend a stiffer line for the spindle coolant? My lines are flexing and almost pinched off in some spots.
  1. Replies: 4
    Last Post: 02-12-2014, 01:17 AM
  2. LIMAC 4 head cnc router for carving
    By limacchina in forum Uncategorised WoodWorking Machines
    Last Post: 09-09-2013, 08:11 AM
  3. CNC Wood Carving Router
    By omnicnc in forum Omni CNC
    Last Post: 12-03-2012, 10:23 AM
  4. Foam Carving CNC Router
    By Alan_c in forum DIY CNC Router Table Machines
    Last Post: 05-26-2009, 10:59 PM
  5. Which CNC router for wood carving is good
    By CNCguy82 in forum Want To Buy...Need help!
    Last Post: 08-04-2008, 06:02 AM
