586,121 active members*
3,184 visitors online*
Thread: Lasercut 5.3
    Mar 2013
    6
    Lasercut 5.3
    Have a problem whereby the engraved image is not the same size as that stipulated on the Lasercur screen.................
    Can, and how, do I fix this?
    Joe Slater
    Jan 2012
    43
    I had the same problem after reinstalling lasercut. A 50mm sq was 47mm. try adjusting the PULSE UNIT and both the X/Y axis from the option then worktable menu.
    (write down the original settings). Pg 42 in my manual, yours may be different.
    Rick
    Mar 2013
    6
    Thanks Rick - took a little while but here is my 'furmulae'- works like a dream!!
    Step 1. Cut a square 100 x 100
    Step 2. Take the size of the wrongly sized cut square, in my case it was 92 instead of 100
    Step 3. Divide the size, i.e. 92 – by 100. This give you 9.2 – change this to .92
    Step 3. Take the reading for x and y axis in the Machine options Worktable, click the little square next to the reading – this reading should be +- 33. Multiply this number by the .92 arrived at. Enter this figure into the little square reading.
    Step 4. Download configuration.
    Machine should be OK now!!!!./
    Nov 2009
    314
    Yes , it could be happen .As Rick says ,it is related the pulse unit in option ~
    Best regards ,
    Mary Lee
    XYZ Machinery
  1. Need a little lasercut help...
    By phylo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-15-2013, 01:27 AM
  2. LaserCut 5.0
    By edsawen in forum LaserCut
    Last Post: 08-21-2012, 03:08 PM
  3. Lasercut
    By TheMadEtcher in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-21-2010, 09:03 PM
  4. Lasercut V51 - HELP!
    By TheWorkshopGuy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2009, 11:25 AM
  5. Lasercut 5.3 (5.2)
    By bibi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-18-2009, 03:42 AM
