586,640 active members*
2,646 visitors online*
    Sep 2009
    277
    Straight Flute End Mills
    Hi All
    I have been battling to cut 3mm (1/8") MDF for my daughters doll house. I can't find reasonably priced downcut end mills SO i ordered some straight flute carbide end mills I found on eBay.
    I guess I could pepper the 1200x1200 MDF with screws but that would take TONS as the parts are small.
    SOOOOOO... will the straight flute help with that problem?
    Thanks in advance.
    Sep 2009
    277
    OK so let me respond to my own thread
    YES straight flute end mill will DEFINITELY do the job. It is AWESOME to work with and does a fangtastic job. For wood I would definitely recommend straight flute!
    I have ordered a bunch of then is different sizes. For thin material I thnk they are awesome.
  1. 3 flute End Mills, how do you measure Dia.
    By Gerry Sweetland in forum Tormach Personal CNC Mill
    Last Post: 03-19-2012, 02:54 PM
  2. Why are four flute end mills better for steel?
    By TXFred in forum Material Machining Solutions
    Last Post: 09-25-2010, 07:38 AM
