Re: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spi
Yesterday I made up 6x tool holders for the Monster, 4x 1/4" & 2x 1/8" & 1x setting gauge. The tool holders are long enough to hit bottom in the spindle's nose, giving me a solid datum to stop against. So the procedure is to measure the length of the setting gauge with a digital caliper, and set it's DRO to zero. Now I can measure the length of the tool holder with a cutter installed, the caliper will automatically deduct the length of the setting guage and give me the tool's cutter length.
Now I can enter all the tool lengths into Mach3, and use the z-tool setting block to set tool#0 to Z-zero. I have written a template G-Code with all the offsets & coordinates for manual tool changing, all I need to do is cut & paste the g-codes from VCarve-Pro into the template. This process works great, and speeds up production on many items I make, at least it does on my little machine in the back room!
For some reason, Mach3 is ignoring the T1 & H1 commands, and continuously uses tool #0
(Set Z=0 on top of part )
(G54 Set x,y,z zero at HOME position)
(G56 Center of and Z-Zero +0.750 above fixture top)
(Tool#1 .625 Dia x0.75 endmill)
(Tool#2 .250 Dia x0.50 endmill)
(Tool#3 .750 Dia 60-Deg V-Bit)
(Tool#4 .250 Dia x0.75 endmill)
G40 G17 G80 G50 G90 G56
G49 M5
G0 X0 Y-10.400 Z4.600 (tool change position)
M1
T1 H1 (Tool#1 .625 Dia x0.75 endmill)
S25000 M3 G04 P10
(insert code here)
G0 Z0.8000
G49 M5
M1
T2 H2 (Tool#2 .250 Dia x0.50 endmill)
S25000 M3 G04 P10
(insert code here)
G0 Z0.8000
G49 M5
M1
T3 H3 (Tool#3 .750 Dia 60-Deg V-Bit)
S25000 M3 G04 P10
(insert code here)
G0 Z0.8000
G49 M5
M1
T4 H4 (Tool#4 .250 Dia x0.75 endmill)
S25000 M3 G04 P10
(insert code here)
G0 Z0.8000
M5
Can anyone tell me why the tool lengths are being ignored by Mach3?
Widgit
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
