586,106 active members*
2,987 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle
Page 88 of 91 38788687888990
Results 1,741 to 1,760 of 1805
  1. #1741
    Re: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spi
    Progress!
    I have a PC with Linux Mint installed, now I have to learn how to use it!
    BigRed is running on an old PC with XP, everything is working nicely except the Touch-Plate!
    No matter what I do on the on Mach3 & the PMDX-126, the probe doesn't show up!
    Its a 1" thick plate, which registers as a ground connection on my Volt Meter!
    Also have Blue-Screen installed in Mach3
    Manual says wires go to J11, Pin 9, but its not working???
    Any ideas?
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  2. #1742
    May 2007
    102
    Glad to hear it's resurected .
    Tell me , if you're running XP anyway , why the motion controller ?
    I mean XP supports the parallel port right , and a chinese breakoutboard will cost less then 5$ .
    Pat
  3. #1743
    Quote Originally Posted by stragenmitsuko View Post
    Pat
    Not useful!
    As I already have the boards!
  4. #1744
    Sep 2011
    281
    what happens if you ground that plate at the computer? does it trigger then?
    Colten Edwards http://www.cncsigns.ca
  5. #1745
    After several days, I’ve finally got BigRED back to work!
    There were several issues with grounding, and shielding noise in a few cables!
    With an old PC, i can get some things carved, while i learn how to operate LINUX Mint!
    The little machine is still down, but I’m making progress on it too!
    I’ll post some videos of BigRED at work!
  6. #1746
    Mar 2004
    1806
    Fan Friggin Fantastic!
    I knew you could do it:})
    Art
    AKA Country Bubba (Older Than Dirt)
  7. #1747
    Hows this for a First Article !
    40" x 14" x 1 1/2" Yellow Pine laminated with biscuits, then hand painted!
    BigRED was well behaved, after fixing all the noise & ground connections!
    Run time at: 3hr
    Paint time at 6hr
  8. #1748
    Mar 2004
    1806
    Yep, your back in your stride and producing outstanding work as usual.
    Glad to see Big Red up and running again. It was worth the effort.
    Art
  9. #1749
    Apr 2005
    1268
    Looks Fantastic Widgit;
    The painting skills appear to fall right in line with the machining skills. Perfection!
    I'm also starting a Linuxcnc conversion on my small router. I just don't trust Mach and have been running pathpilot on my Novakon for quite a while. It appears to be rock solid but I still need to learn a bit more about the platform. I'm toying with the idea of a tool changer for the Torus which will be controlled by Linux (I hope).
    Keep up the artistic endeavors. Your posts inspire us little folks!
    Have a great day.
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
  10. #1750
    May 2007
    102
    Big red's alive
    Good news indeed .
    Can't wait to see the next pieces of art it'll create .
  11. #1751
    Thanks Guys!
    I hope BigRED stays online for a long time!
    As I ave a few more ideas worthy of carving!
  12. #1752
    Apr 2007
    8082
    Re: Can anyone tell me if Mach3 will run on Windows 10?
    Glad to see that you are back in action sir.
    My two old 386 processor CNC machine computers are still operating, but recently they stopped booting up unless I fiddle with the F1 and F2 keys and BIOS settings to get to the Windows startup screen. I finally had some free time available to replace the CR2032 batteries in the computers so that the computer can save some of the CMOS settings that are temporary. Now they are back in operation normally. What a relief!
    They both have been kept very busy in the past five months.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
  13. #1753
    Thanks Carv'e, good to hear from you!
    Hows this!
    Had to make a full set, one for each branch!
    All hand-painted, ready for the clear coat!
    each one is 24" x 10" x 1 1/4" yellow pine.
  14. #1754
    Dec 2004
    1865
    Hi Widgit,
    Beautiful work as always. Someday when I grow up...........
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
  15. #1755
    Here's another one Bubba!
  16. #1756
    Mar 2004
    1806
    I sure would like to have one of those! You improve with each one of these.
    Art
  17. #1757
    Dec 2004
    1865
    Beautiful work as always, Widgit!
    Mike
  18. #1758
    Thanks Guys!
  19. #1759
    Well, Big-Red is functioning nicely! I've been able to make some really nice large plaques!
    The old Win-XP system is ok, as the date was set for 2017!
    So far I have purchased an ESS Ethernet SmoothStepper for both machines,
    Along with the 5-VDC power supplies for the SmoothSteppers! And a Panel mount RJ-45 cables!
    Then I acquired two Dell-990 PC's with Windows-10 installed. Each PC will have a 2nd PCI Ethernet card to connect to the SmoothSteppers!
    When I,m satisfied all is setup correctly, I'll hook one of the PC's to Big-Red!
    I've decided to sell the small CNC router when its running smoothly, and use the money for additional Hyperbaric Oxygen treatments! As I have had 135 hours so far, and the repair results on my body were absolutely amazing!! My foot is almost 100% healed, and it's been three years now! The ringing in my ears is totally gone, and I now sleep better than I ever have! The PTSD had me tossing about in my sleep, and the nightmares sucked! Now its all gone!! But I do have an open wound on my heal, and I'm worried it will get infected if left open! Just glad to be ALIVE!
    By the Way!
    This post was made on my New LINUX-MINT system, using FireFox !
    Progress!
  20. #1760
    Mar 2004
    1806
    Excellent as it sounds like your making positive progress on all fronts. Hang in there my friend as you are always in our prayers and keep up the great works that you do.
    Art
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  3. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
  4. 4-axis CNC-router, NEMA23 steps, Gecko 540, Water cooled spindle
    By Vaffel in forum CNC Wood Router Project Log
    Last Post: 10-18-2010, 08:54 PM
  5. Water cooled spindle need ???
    By BFcarbon in forum Commercial CNC Wood Routers
    Last Post: 03-04-2006, 10:05 PM
