widgitmaster
Widgit the Zone has been having problems, I found a way that seems to work if you are still having problems
when the you first open the main Zone page, don't log in unless you have logged out, just hit ( todays posts ), then when that has loaded hit ( new posts ) & all is working, refresh the page helps sometimes as well,
As far as your spindle braking goes, Mach 3 has nothing to do with it, only the output of M5 & the PWM connection to the VFD, if all that part is working, the VFD does all the braking work
The external mounted Braking Resistor is what you want, then some parameter changes in the VFD will help you slow the spindle down, But first lets check to see what you have it set at now,
The VFD that you have is not very good at slowing down to fast as you found out before
What do you have these Parameters set at, these are the 2 parameters that affects how the spindle stops
PD015-------
PD26--------
