hi all
the machine is hitachi seiki VA-55 with fanuc system 11M,
after the machine was turn off correctly, the next morning when I turn on the machine started up
there is no alarm or error but the mode selected on the control panel REF/RPD/JOG/HND/MDI/EDIT/MEM/TAPE won't stay steady on the screen
it is continuously changing between the mode selected and the REF
for example mode switch is set on MDI but on the screen every second is changing: MDI then REF then MDI then REF and so on
when I put the machine in REF mod I can send all axis in referent positions no problems at all but
when I put on RPD mode and try to move the axis because the mode is changing all the time i get noncontinuous movement.
I don't have much experience in reading ladder diagram to find my self the problem so any help would be appreciated
regardless if it is for the problem or directions on how to find the problem with reading the ladder diagram.
:drowning:
