586,052 active members*
3,894 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > issue with chamfer in update 996 v25?
Results 1 to 8 of 8
    Jun 2012
    514
    designed a part with the new update 996 and found that the chamfer feature always goes back to flat point chamfer instead of sharp when i compute toolpath. it will show the picture for the flat chamfer mill but keeps the selected sharp chamfer mill int he check box. BUT when i choose compute all toolpath it will definitely change the program and the flat chamfer mill end sup being what the machine runs...but you get NO INDICATION that it changed...the simulation shows it changed...
    how do i know???? screwed up 2 god parts on the last tool feature ran tonight before i figured out what the hell was going on....
    anyone else have this issue with update 996???
    Big Chipin, spreading tha cheese, I be Big Chipin for days!
    Apr 2009
    3376
    Did you enter an amount for the small end diameter ?
    Seems to work here.
    God parts,uh oh.
    Dec 2008
    4548
    Seems to be sticking over here.....
    Jun 2012
    514
    yes it will stick... but did it do so in simulation AFTER you compute toolpath and then compute all tool path ?
    Jun 2012
    514
    yeap..i have a bug..does this on 2 of my 3 seats (have not tested 3rd seat/computer)... once you compute all tool path it will change..
    burr /jr send me your emails and i will send you both the file this is happening to....so you can assist and see what i am talking bout
    Dec 2008
    4548
    I cant seem to get it to loose the seeting no matter how I compute-simulate, compute all-sim-compute while sim etc....
    Before you send files, have you tried to re-create the chamfer from scratch? ie; dont use the bbcd file or a saved feature. Re-create the chamfer feature.
    burrmanator at gmail dot kom
    Apr 2009
    3376
    Are you still needing help ?
    Jun 2012
    514
    i think it may be the cad drawing....other drawings i have work fine...so something is working funky on my geometry.... thanks jr
  1. tapped hole chamfer with iscar chamfer tools
    By dcutler35 in forum Mastercam
    Last Post: 12-07-2012, 02:30 PM
  2. Chamfer chamfer mill or ball mill
    By fjbart70 in forum Mastercam
    Last Post: 03-11-2011, 06:27 PM
  3. Update to -5 now rigid tapping issue
    By carbidecraters in forum Fadal
    Last Post: 02-15-2011, 06:36 PM
  4. help with 3d chamfer
    By Justin Cavender in forum Mastercam
    Last Post: 01-23-2011, 10:56 PM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
