586,067 active members*
4,749 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 10T Turret Rotation Problem
    Jun 2013
    I have a Takamatsu CNC Lathe Year Make 1986. It has a strange problem. sometimes during a program turret forgets to rotate ( one tool to another). resulting new tool doesn't come in front of chuck and old tool hits in job.
    this problem comes after 2 to 3 hours of operation.
    any one can help me the root cause of this problem.
    regards in advance
    Sunny
    24221
    There is something odd with the Tool change logic, normally the turret/tool change requires a FIN confirmation signal that the turret has rotated to the commanded position, otherwise either the program would 'hang' or a fault message?
    If the logic IS right, then somehow the controller thinks the turret has rotated already, which smacks of a sensor or other fault?
    The ladder would have to be displayed and studied to solve the problem.
    Al.
    Albert E.
  1. Replies: 11
    Last Post: 11-01-2012, 10:10 AM
  2. FANUC 6T Turret Problem
    By kulbir in forum Fanuc
    Last Post: 04-14-2010, 08:33 AM
  3. Replies: 5
    Last Post: 02-12-2010, 01:16 AM
  4. Okuma act 3 with Fanuc 6T turret problem
    By peterson76 in forum Okuma
    Last Post: 08-03-2009, 10:44 AM
  5. G68 Rotation problem on Fanuc 180i
    By btdmfg in forum Fanuc
    Last Post: 12-05-2008, 01:58 AM
