586,104 active members*
3,378 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Building a power supply with decent volt/amperage
Results 1 to 5 of 5
    Jun 2005
    866
    I can't find a power supply that fits my needs, so I'm afraid I will have to attempt to build one.
    I have 3 motors to power (for now). two 400oz 5amp motors frm IDC, and one 270oz motor from LIN engineering.
    As this project gets more and more sophisticated, I will get get more 23 frame motors but I have a power supply already for that.
    My drivers will take up to 100v, 8 amps per motor. Can somebody help me out in choosing parts to build this thing? I have limited electrical experience, though I have come a long ways since when i started CNC as a hobby.
    Mar 2005
    523
    looks like your drives will handle 800 watts.
    if you can find some toroid isolation transformers at 1000 watts, you could just take off a few turns from the secondary till u get the desired voltage out.
    this is providing you are in north america where the line voltage is 120vac.
    then go through a 25 or 35 amp rectifyer bridge.
    put some filter caps on the dc side rated above your dc output.
    at least 20,000 uf, put a voltage draining resistor on the caps.
    ... there you have it, 1 maximum power supply for 1 drive.
    1695
    Phant: What drive are you using? If you're using nema23 motors, you won't need a very large power supply.
    Jun 2005
    866
    The X and Y axes are nema34 frames. THats why they are 5amps, I think they might even be a little more, have to check the data sheet at some point....
    Drives are being custom made by a very savvy friend of mine.
    Jan 2006
    481
    Quote Originally Posted by phantomcow2
    hi phantomcow
    try this link and the person who wrote it is CNCadmin
    CNCadmin has also another thread but couldnt find it maybe PM him and ask for a link , this other thread he posted was a well detailed document on how to make a power supply from scratch and explained all the ins and outs of power supply for a specific need.
    http://www.cnczone.com/modules.php?n...warticle&id=27
    will be a very interesting reading if anything , hope it helps
    cheers
