586,103 active members*
3,667 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > TOROID TRANSFORMER info needed - have spec sheet
    May 2004
    200
    I was able to pick up a TOROID TRANSFORMER @ HSC (http://www.halted.com/) for $14.95
    its rated @ 70V with a centertap so 35V on each side. Im trying to understand the spec sheet. I want to know what the VA output is.
    hope someone can help me out
    spec sheet
    746
    From it's size in the picture and the tag on the side it looks to be 650va.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
