586,461 active members*
4,464 visitors online*
    May 2013
    20
    TL-1 RPM default
    I have just purchased a 2007 TL-1. When I try to run it in manual mode, no matter what RPM I set, it will only run at 50RPM. Is there a setting somewhere that needs to be turned off? The lathe was in a school so I'm thinking maybe a safety thing? Any advice would be helpful, thanks.
    Jul 2005
    12177
    Look through the Parameters and you will find one that mentions MAX RPM DOOR OPEN. Cannot remember the number.
    May 2013
    20
    Thanks Geof, you hit it right on the head. That's great but it now wont let me change the parameter. Must be a lock somewhere. Can you point me in the right direction?
    Jul 2005
    12177
    Setting 7 Parameter lock, turn it off using the right cursor key followed by the write key
    EDIT
    Yes I forgot E stop
    Mar 2010
    1852
    Quote Originally Posted by Geof View Post
    Also must hit E-Stop first!
    Mike
  1. CNC default setting
    By Bisorcam in forum Mastercam
    Last Post: 04-08-2012, 09:46 PM
  2. Spindle default at 250
    By cuttingedgepart in forum Tormach Personal CNC Mill
    Last Post: 10-23-2010, 02:57 AM
  3. default units
    By canadamaxxer in forum Solidworks
    Last Post: 10-07-2010, 07:05 PM
  4. V8 default values
    By mjp in forum Mastercam
    Last Post: 01-01-2009, 03:22 PM
  5. Change default nc extension
    By Big John T in forum Post Processors for MC
    Last Post: 06-04-2008, 09:29 PM
