Attachment 187966
Recently, SteelTailor have manufactured a new kind of portable plasma cutting equipment which can match with hypertherm powermax105 perfectly. Why I say so? Pls see the following reasons.
1、110v or 220v auto switch Flame feature optimized Better quality in components。
2、The warranty of this plasma cutting equipment is 2 Year ,longer then all the machines before Jan,1st 2012.
3、Default configuration: firstly,flame/Plasma automatic sensing THC,Secondly,basic nesting software for free
4、Oxy-Fuel cutting feature upgraded.Firstly The gas tube is laid outside the cross-beam, makes maintenance easy.Practical plasma cable support frame.Secondly,pre-heat Oxygen is CNC controlled. Easy operation, Non-stop cutting.
5、Advanced Stability The X-axis drive mode of this plasma cutting equipment is optimized for SteelTailor Power. The introduction of guiding rail in the x-axis of powerII plasma cutting equipment, enables a more stable movement of the crossbeam and avoids the cutting head from declining.
6、The cutting area of PowerII plasma cutting equipment is bigger: Max. Cutting Area:1.56M × 15.00M ( 5.12’ X 49.21’ )
7、The voltage range of powerII plasma cutting machine is 95~250V .This is adaptable to all the civil power supply all over the world.
8、Guiding System of the Cross Beam
9、Cutting HeadDoes Not Decline
Pls see the following advantages of Hypertherm Powermax105:
1.The Hypertherm Powermax105 have the maximum power and performance for air plasma.
2. This powermax105 can cut 32mm thick metals.
3. Powermax105’s seven Duramax torch styles provide greater versatility,portable automation,X-Y table cutting and robotic cutting .
4. The Smart Sense™ technology of powermax105 automatically adjusts the gas pressure according to cutting mode and torch lead length
5. Powermax105 also detects electrode end-of-life, automatically turning off power to the torch to prevent potential damage to other parts or the workpiece
You can see all the advantages of SteelTailor PowerII plasma cutting equipment match with Powermax105 perfectly.
Hypertherm designs and manufactures the world's most advanced metal cutting products
SteelTailor offers portable CNC cutting machines,portable table plasma cutting machine,CNC plasma and flame cutting machine,cnc plasma cutters
Home | SteelTailor portable cnc cutting machine gallery,product photo,cutting sample images
SteelTailor PowerII plasma cutting equipment match with Powermax105 perfectly | SteelTailor' Blog
