586,089 active members*
3,902 visitors online*
Results 1 to 9 of 9
    Jul 2005
    23
    Not sure if this is a Mach4 question or G-Rex
    But here is goes.
    I am converting a Bridgeport Boss 5 to servo's and Machx. I want to use separate MPG's to contol each axis (instead of one MPG and a selector switch.)
    Can I use the encoder inputs (the A,B and C axis) on the G-rex to accept MPG inputs to drive the X,Y and Z axis?
    If so it also looks like the G-rex can be run in autonomous mode and be controlled with the MPG's to make a pseudo manual mill.
    Steve
    First, don't make duplicate poosts, it's against forum rules.
    Mach4 isn't finished yet, and I doubt that would work at this time, but I'd imagine that this will be implemented when it's finished (2-3 months, probably). Best to email Art directly and ask, but he's been on vacation and it may take him a week or so to get caugh up. [email protected]
    If you plan on actuall using the MPGG's to do manual milling, it seems to me that using MDI mode would be much simpler.
    Oct 2005
    215
    You can't use the parallel port and the GRex together, it is either one or the other. I got clarification from art on this.
    Jun 2003
    2103
    Gerry I think it would be a lot easier to turn a handle that to type all the info into the MDI. I may be misunderstanding what is wanted here but I think he wants a manual/cnc mill and the mpg's would do that.
    Mike
    ps wouldn't it?
    No greater love can a man have than this, that he give his life for a friend.
    I think it's a matter of personal preference, but I think for actual milling, MDI would give better results. jmo.
    Jul 2005
    23
    Yep, that is what I want to do. If the inputs could be mapped to Mach it should work. I don't want to be typing when I am milling something, just turn the handles.
    Quote Originally Posted by turmite
    Mike
    ps wouldn't it?
    Jul 2005
    23
    I still don't kwow if it's a Mach or a Gecko question. And I have read the manuals.
    Sorry about the mix up. I accidentally changed your post when I meant to reply to it.
    I was saying that it's a question of whether or not Mach4 will have this feature. I'm pretty sure it will.
