587,030 active members*
3,626 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Retrofit of Gerber d200 to use Gecko g540 controller.
    Jun 2013
    Gentlemen,
    I am retrofitting a Gerber D200 with a new useable controller to support Mach3. I want to use the G540 stepper controller. I need to know if i need to swap out the stepper motors. I can't find enough documentation on the current steppers to know if they will work with the G540.
    The current motors are SLO-SYN model M062-LS-530E. They seem to no longer be in production. They are in almost new condition. It would be a shame to scrap them.
    Can anyone confirm if they are compatible with the G540 or not?
    Kevin
    Sep 2004
    35
    Looks to be a 60mm(NEMA 23) and seem like the Gecko 540 might be able to drive it depending on the exact spec of that particular M060. (540: max 3.5 A => specs: http://www.geckodrive.com/support/mo...540-rev-8.html )
    SloSyn spec sheet linked below is the start of understanding and a call to tech support of the manufacturer or a dealer should sort out the details.
    Specs for MO60 SloSyn Steppers: Standard 60mm Frame Size (NEMA Size 23)
    MC SUPPLY CO: Bodine Electric Co, KB Electronics, Brake Motor, Stepper, Gearmotor, Gearboxes, Clutch/Brake
    Notes:
    http://www.electrosales.com/warner/p...ogslosyn-c.pdf
  1. A Gecko G540 retrofit for a Techno Router
    By dmauch in forum Techno CNC
    Last Post: 04-17-2020, 09:43 AM
  2. Gecko G540 4-axis Stepper Controller Kit and Schematic
    By phomann in forum Australia, New Zealand Club House
    Last Post: 01-19-2010, 01:38 AM
  3. Replies: 31
    Last Post: 11-27-2008, 06:55 AM
