586,075 active members*
4,267 visitors online*
Results 1 to 6 of 6
    May 2013
    24
    Question KRMx01 and LinuxCNC
    My KRMx01 seems to be running fine. I am currently using Mach3 and Cut2D.
    I have a lot of experience with Linux but very little with CNC Routers. Is anybody
    Running EMC2? Did you just transfer the settings that you used in Mach 3 to the EMC2
    settings?
    Jim
    Aug 2010
    686
    Not sure if the Mach3 Gcode I created for the various tests and upgrades is compatible with EMC. Anyone wanting to use Linux and EMC might want to do a dual boot situation so you can access original Mach3 files.
    Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
    Mar 2006
    115
    Re: KRMx01 and LinuxCNC
    Not sure if this is a dead post or not but I am running mine with LinuxCNC (EMC2) and cover what I done to set it up. As I apply upgrades to the machine, I will explain those configs as well.
    Joe
    Aug 2010
    686
    Well over a thousand folks purchased the KRMx01 books off of Amazon and other sources and are still doing so on a regular basis. My metrics show that the download version is getting about 300 downloads a month, so I would say it is active.
    That said not everyone who purchased or downloads the book will build it. Some use the book as reference.
    I would be interested in any alternate control methods for the KRMx01 machine. I have recently been experimenting with the Arduino and have successfully used it to run my KRmf70 builds.
    Mar 2006
    115
    Mike,
    Quote Originally Posted by msimpson99 View Post
    Glad to know that the KRMx01 is still going strong. I have got several emails about my build over the last year.
    You know how life goes, you get so far then something else gets in the way. I am still working on my machine, mostly cosmetic but still have things to install and set up. My intention is to create a series of tutorials and videos on setting up the KRMx01 for use with LinuxCNC. You are welcome to reference them if you like. Or if you need something more, then let me know. The thing I am trying to do is keep people from being tied to brand x controller, or brand y BOB, etc. I want to give enough information so that a new comer to CNC can figure out how things are inter-related.
    Joe
    Aug 2010
    686
    Did you ever create those LinuxCNC tutorials. I am interested in playing with alternative control methods with all my machines.
  1. KRMx01 CNC Machine and LinuxCNC
    By wxgeek in forum LinuxCNC (formerly EMC2)
    Last Post: 06-20-2013, 03:15 AM
  2. Dumpster Nuts on KRMx01
    By msimpson99 in forum Uncategorised WoodWorking Machines
    Last Post: 05-29-2013, 04:18 AM
  3. KRMx01 Z Plate drawing now available
    Last Post: 03-26-2013, 12:01 PM
  4. KRMx01 Build Log
    Last Post: 01-25-2013, 01:12 AM
  5. New Z-plate available for KRMx01 build
    By msimpson99 in forum DIY CNC Router Table Machines
    Last Post: 01-08-2012, 06:38 PM
