586,104 active members*
3,449 visitors online*
    Feb 2006
    183
    Mach3 limit switch problem on Ref Home
    Each time I try to ref home, Z goes first, then Y, but Z doesn't make it because a limit switch is cutting in and out. The circuit uses the same input for all 3 switches, so the others are still too close.
    Is there a way to back off the switch just a bit more? Homing works fine with the so-called software supplied by the manufacturer.
    Oct 2003
    927
    Possibly try setting a high(2000) in the "debounce" under configs/logic.
