586,103 active members*
3,474 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > Blower for The Demon V8
Page 1 of 5 123
Results 1 to 20 of 82
    Dec 2006
    603
    I got the bug to make a few parts for the Demon blower. I have a lot of prototype parts but have never built one so I decided to make the intake manifold and go up from there. I used the manual mill to rough out the basic shape of the intake and then the CNC mill to start shaping things. It took 3 tools and about an hour and a half to get to this point.
    I also made a pattern and poured a few cases for the blower.
    I will most likely bounce back and fourth between this and the mini bikes so both builds will take twice as long now.
    Oct 2006
    708
    Nice, Steve!
    What alloy did you use to cast? It looks like you have done it before?
    Dec 2006
    603
    Quote Originally Posted by dynosor View Post
    Nice, Steve!
    That is actually the firstcasting I have made that is going to get used. I have cast before but just for demo or making ingots.
    The alloy is just a bunch of scrap that was laying around the garage. What ever was in the melt bucket.
    Oct 2006
    708
    Pretty good results, especially for a first try. Can you post more details about your mold, ladle and melting method please.
    This means you could cast your own engine blocks, if you wanted to, like these guys.
    Casting Ferrari - YouTube
    How It's Made Engine Blocks - YouTube
    ferrari V12 building - YouTube
    Note the pouring from the bottom of the crucible to minimize slag inclusions:
    Dec 2006
    603
    Got the top and bottom complete. I just need to drill the holes to mount it and port the blower to the cylinders.
    Dec 2006
    603
    The furnace is a 5 gallon bucket converted to a furnace. I use a steel pot to melt the metal. The pattern is just a simple wooden pattern made from maple. Standard sand casting with petrobond. This was done at the names show. The pour in the flask was the blower case and the pour in the bucket was a lost foam demo.
    00021 - YouTube
    Oct 2006
    708
    Awesome!
    Thanks Steve.
    Dec 2006
    603
    The intake is complete. The ports are drilled and the coolant passages are in. For the first time a blower is bolted to one of my demon blocks.
    I'm liking it so far.
    Dec 2006
    603
    I have my blanks made up for the rotors. The length is dead on and the diameter is .125 inch larger than needed. The shaft is a pressed fit but I used a grooving tool and made some .010 deep grooves and filled them with loc-tite before i rammed the shaft thru.
    Here's my setup. The fixture is steel with brass bushings. I spent better than an hour shimming and tapping and indicating to make sure i am perfectly aligned. It's ready to go. If work gets rained out tomorrow I might take a run at one rotor. The RT is for rotating and holding position. The fixture does all the work. With a .188 shaft I didn't want to rely on the RT to support the work. I was worried about the center shaft flexing. I have only allowed .005 clearance in the case so I need all the advantage I can get.
    6855
    WOW that is a sweet engine!
    Dec 2006
    603
    Thanks! It will be awesome if it works the way it's supposed to.
    Dec 2006
    603
    All went well with the first piece. In this extremely poor quality video you can see the blank has been rough cut and the profile of the lobe is getting cut into the blank. The profile gets cut and then the cutter steps over 3 thousands and cuts again. The cutter walks all the way down the length of the piece. The part is rotated 120 degrees and the same program is used 2 more times.
    BlowerRotorLobes - YouTube
    After 2 runs
    After all 3 runs
    Then the blank gets rotated 60 degrees and this program is run 3 times every 120 degrees. This one works the same way and cleans out the valleys.
    BlowerRotorValleys - YouTube
    If all goes well I hope to clean up, setup the second blank, and get it indicated in and ready to cut for friday.
    Oct 2006
    708
    Steve, what diameter cutter did you use for the blower impeller, at what speed? Assume it is a ball nose cutter?
    Dec 2006
    603
    1/8 inch ball nose at 30 IPM with .0035 step over
    Dec 2006
    603
    Well! It's official, I now have a pair.
    They still need to be deburred and geared together so i can see how they run together. The fit seems very promising. I'm sure there will need to me some fine fitting with some fine grit sand paper.
    Dec 2004
    1865
    Very nice work Steve.
    One day when I get caught up on all the stuff that I have to do I can work on the stuff that I want to do.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Dec 2006
    603
    I try to get out in the garage at least 2 nights a week after work to make something. If I do that I seem to make decent progress.
    Dec 2006
    603
    After 2 days of filing, dying, testing , and sanding, fitting, massageing, and tinkering, well you get the point. The rotors are fitted to the case. The rotors free spin and nothing touches nothing.
    Oct 2006
    708
    Steve,
    For some reason your images are not displaying here today - none of them.
    I managed to see them at Photobucket by following the links visible when quoting your latest post.
    Jolly good show!
    Dec 2006
    603
    They will be back after the 6th of next month. I've exceeded my band width for the month and i'm too cheap to pay for more.
Page 1 of 5 123
  1. Steve Huck's Demon V8 version 1.5
    By cforcht in forum I.C. Engines
    Last Post: 04-25-2022, 02:54 PM
  2. Demon V8 updates, getting them?
    By stevehuckss396 in forum I.C. Engines
    Last Post: 02-08-2014, 06:25 PM
  3. Fan , blower , connection , help
    By josvanhout in forum CNC Machine Related Electronics
    Last Post: 11-03-2013, 10:40 PM
  4. Building a Little Demon V8
    By maxine in forum I.C. Engines
    Last Post: 06-21-2013, 06:21 AM
  5. Vacuum or Blower
    By stickermanstl in forum Commercial CNC Wood Routers
    Last Post: 03-04-2010, 01:38 PM
