586,115 active members*
3,458 visitors online*
    Oct 2008
    8
    alarm code 39-89
    Getting alarm code 39-89 during Machine Alignment Procedure
    Sep 2010
    1765
    bet it says more than that..... some of us are not cincinnati field service reps so do not have codes memorized from 30 yrs experience. but we may have worked on these machines for 30 years and can help you if u tell us what this criptic code also says on ur screen....
    Jun 2014
    Re: alarm code 39-89
    Quote Originally Posted by mike_Kilroy View Post
    i am currently having the same issue. i will type up the details on the alarm code. Cause: Bit Z of S1AX_MOTION is ON, which indicates motion present in the C axis. Remedy : check the "in position" window value against the following error for the Z axis. Also, check the balance figure in closed loop mode is not excessive. This can be viewed and altered in the servo setup page
    Dec 2006
    584
    It would help to know what machine you are talking about, what control is on it and what drives you have!!!!
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Aug 2022
    i have the same problem it is a cincinnati arrow 750, acramatic control 2100, with cincinnati BDS4 servos
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. alarm code 401
    By chicocnc in forum Laser Hardware
    Last Post: 05-06-2014, 02:09 PM
  3. HELP QT 350 alarm code 371 turret servo alarm
    By kirkmach in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-19-2011, 09:39 AM
  4. 971 NMI in SLC Alarm Code
    By bmhall317 in forum Open Source CNC Machine Designs
    Last Post: 02-26-2010, 04:34 PM
  5. Alarm code 203-6
    By meszarosg in forum Okuma
    Last Post: 10-11-2008, 09:17 PM
