586,540 active members*
2,668 visitors online*
Results 1 to 8 of 8
    Feb 2011
    38
    Tree with Dynapath will not repeat
    My Tree J-425 with Dynapath 40 controller runs good but with a snag. Every time you hit cycle start, The machine does not go to the same place twice. Machining a part that already has cut features will find the new cuts off location. Changing x and y offsets to correct the problem is of no use as the machine is always off location again. Can someone tell me where to look for a fix? Location can be off by .005 in any direction. A part machined in one set-up is better but not perfect.
    Thanks!,
    Erik
    Feb 2009
    6028
    Probably needs new drive belts, but are you talking after power up/restart or just part to part.
    Feb 2011
    38
    This would be part to part I'm concerned with. In the morning, X homes where it should but Y can be off by .100.... I always re-dial x and y on start-up. I know I shouldn't have to but until I get it figured out..... Z is always perfect.
    Thanks!
    Feb 2009
    6028
    Move the Y switch about .02" to fix that. You simply are triggering home right at the reference mark on the encoder, so it is hit and miss right now. Your initial problem sounds like worn out timing belts on the axis. Make sure your getting plenty of lube on the ways, and hit the zerk fittings on the ballscrew bearing housings with EP2 grease.
    Feb 2011
    38
    Wow, never would have thought about the belts..... Anything special I should know before I order some? Tension? The ways and ball screw bearings are lubed good, everything is dripping all over the floor! I will bump the Y stop and test out the home also.
    Feb 2009
    6028
    Just don't over tighten the belts, other than that nothing special. 10 minute job really.
    Feb 2011
    38
    OK, the belts are on order. I bumped the stop .02 and it still missed the mark by about .1 when I powered up the 2nd time. Third and fourth power ups homed in the proper place. Bumped it another .01 and tried several more homing routines. So far so good. Will keep trying it until I'm confident it finds the proper home every time.
    Feb 2011
    38
    OK, the belts are on and so far the repeating looks much better. Mr Under-the-tire, I tried to reply to you but your message box is full. Can I PM you some other way?
    Erik
  1. Tree 425 will not repeat location
    By erikh206 in forum Tree
    Last Post: 06-22-2013, 01:07 AM
  2. tree 325 dynapath delta 10
    By cncrouter in forum Tree
    Last Post: 01-02-2013, 02:47 PM
  3. Tree Journeyman 250 Dynapath 250
    By phatfred8 in forum Tree
    Last Post: 12-20-2012, 06:54 PM
  4. tree 310 dynapath 20 wiring
    By garychipmaker in forum Tree
    Last Post: 05-29-2011, 04:14 AM
  5. Dynapath 10 vs. 20 control on TREE 310
    By ken fedirko in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-15-2008, 08:56 PM
